Dashboard removal to replace heater core - Mazda MX6 Forums: MX6 Forum
Old 11-9-12, 17:59   #1 (permalink)
  Total: 10 Power: 0
I am trying to replace the heater core on a 1990 Mazda 626 DX. I read the procedures for this by gavin and am just about done with the removal of the dash. The only problem right now is his was the gt with the electronic center HVAC control panel. Mine is the old fashion kind with the levers and cables. With all the screws removed I can only move it forward from the dash about a centimeter or two. Does someone know how to remove this? Or can I just remove the remaining bolts for the dash and be able to move it enough out of the way to get to the heater core?
Also I went ahead and bought a spectra premium heater core from autozone. I hope that would be good enough.
timberstxs is offline   Reply With Quote
Old 11-9-12, 18:14   #2 (permalink)
STW
  Total: 558 Power: 5
STW's Avatar
The cable operated HVAC panel is a bitch to remove, there's no way round that. The cables are still quite firmly attached to the dashboard frame; the quickest way is just to disconnect them from the HVAC devices. The one controlling flow around the car is on the driver side of the central unit; heat controller is in front and the recycling controller is above the fan. The plastic is brittle by now, so be careful. Fixing a broken HVAC controller horn is no fun task, I can tell from experience.
1988 626 GT Wagon, 2.0 DOHC Turbo | 1988 626 GT DOHC Hatch | 1992 Toyota Carina e GLi | 1991 626 GLX Hatch AWD 2.2l
Old 11-9-12, 20:58   #3 (permalink)
  Total: 10 Power: 0
Ok thanks. So I will just be leaving the front panel controls there and disconnecting the cables where they end.
Old 11-10-12, 2:54   #4 (permalink)
  Total: 553 Power: 5
chief tool's Avatar
yep, thats the way to do it.
Money for nothing and your chicks for free.......
Old 11-10-12, 19:14   #5 (permalink)
  Total: 10 Power: 0
Update. I have the dash off. The heater box out and the new heater core in the heater box. Not tomorrow I hope I remember how things go back together.
Old 11-11-12, 16:37   #6 (permalink)
  Total: 10 Power: 0
Thanks for everybody's help. I have the dash all put back together. Before i put the coolant in I will be replacing the water pump, timing belt, thermostat, crankshaft and camshaft seals. I should be then good to go for a few more years.
Old 11-14-12, 17:50   #7 (permalink)
  Total: 10 Power: 0
Looks like the worst now. I have my car up and running and the new heater core from autozone is spraying coolant all over the place. I am waiting on a call from the mazda dealer to see if they can get me a dealer part at a good price. I dont want to do this again.
