almost... - Page 2 - Mazda MX-6 Forum
post #16 of 29 (permalink) Old 11-26-12, 13:51
Zach's Avatar
Quoted: 6 Post(s)
Power: 6
you're almost right...it's the SHO Taurus motor. Vulcan irons...but that's there the similarities stop
95 Turbo 850 - Alpine White
98 V70 T5 SE - Brilliant Black | ARD Stage 2 | Bosch Blues | Koni FSDs | IPD Springs | Alcantara Interior | C70 Jewel Retrofits | IPD HD End Links | Burned Exhaust Valve
Zach is offline
post #17 of 29 (permalink) Old 11-27-12, 15:06 Thread Starter
zlyricist's Avatar
got her running good and smooth finally! clutch isnt engaging still. going to test the slave and diff tonight. if those test well ill drop the tranny real quick and see whats up
she finally got a bath!
1991 gt - still busted
1999 626 kl manual
2002 maxima
zlyricist is offline
post #18 of 29 (permalink) Old 11-27-12, 20:25
Quoted: 2 Post(s)
That's still a damn nice looking car Z!
mx_masta is offline
post #19 of 29 (permalink) Old 11-27-12, 21:41
she looks beautiful man.
~Patrick~
http://www.pmx626.com/ Your all in one Probe, MX-6, 626 Search engine.
monoxidechild is offline
post #20 of 29 (permalink) Old 11-27-12, 23:44
Zach's Avatar
Quoted: 6 Post(s)
Power: 6
I'm still upset I got rid of my cherry 3.2 motor
Zach is offline
post #21 of 29 (permalink) Old 11-28-12, 11:17 Thread Starter
zlyricist's Avatar
thanks for comments
zach - wtf? that is all
this has been a long time coming because i was working and going to school full time for almost 2 years, but now im not doing either :P
we got a new steering rack, greased and plugged up. no p/s
removed hvac completely.
new stereo! 6x9 components up front behind dash and tweeter in pillar. 6.5 infinitys in rear, alpine type x ported 12 in the rear. yes, she gets down
had to repaint a section to fit in euro tails
painted this bbs rims gold. still want to get some nice 16s and put my mazda 6 brakes on
new 2g struts and springs up front
so with my harbor freight 100$ welder and tools, this is a brief summary of how the swap went. most of you are familiar with what this swap needs
cut part of stock block out to fit vulcan 3.0 tranny, needs clearance for the slave
custom y pipe
custom pass side axle mount
chop 1/2" out of front motor mount, cut out reinforcements on underside of hood. otherwise, it wont close
custom pass side top mount. had to cut some of unibody pass side out to fit pulleys in, rewelded some other steel for reinforcement. no in depth pics, but i do have one
the only thing saving my oil pan right now is the y pipe just barely dangling out in front of it, me thinks i need to make a skid plate??
stock radiator fits if you want it to, otherwise get a smaller one. the fans will need to go on other side
this is how shes gonna look for emissions. looks stock right? lol
i still dont know how im going to fit this blower (or a turbo?) in, but i have to do something towards the firewall side. i can do quite a bit of tucking on the lines and a little bit on the wiring......i might get crazy and cut some of the firewall back to put a fat boy turbo back in there? i kinda want to take this stock 3.0 block to the max to see how much power it can hold on e85. the blower i have can only make 3-400whp depending on boost/application. where as i could bolt up a gt35r and make 450-500whp?
1999 626 kl manual
2002 maxima
post #22 of 29 (permalink) Old 11-28-12, 11:26
Zach's Avatar
Quoted: 6 Post(s)
Power: 6
See that battery...toss that bitch in the trunk and whatever the funk you want up there
Looks very nice! Just make sure you raise the front a tad and yes, put a skid plate up there. You don't want to hit a decent sized rock that takes your exhaust and oil pan and rips it off the car lol
Zach is offline
post #23 of 29 (permalink) Old 11-28-12, 11:59 Thread Starter
zlyricist's Avatar
honestly i want to keep as much weight in front as possible! my turbo kl could sometimes peel every gear up to 4th gear if the roads were cold enough....traction issues are always frusterating lol
pulling out everything behind the dash was probably 50 lbs maybe more? adding the sho engine, +100 or 150?
1999 626 kl manual
2002 maxima
post #24 of 29 (permalink) Old 11-28-12, 12:44
Sounds like the set up im running on my beater 626. 16in 2piece Enkei 92's and mazda6 brakes in the front. But also have the 98+ 626 rears since its a GE.
~Patrick~
post #25 of 29 (permalink) Old 11-28-12, 13:01
Zach's Avatar
Quoted: 6 Post(s)
Power: 6
I think it might be heavier than you think. The SHO motor is a heavy ass bitch. I could barely rotate it on the engine stand without needing help. Didn't need help with a KL or F2 on it lol
Zach is offline
post #26 of 29 (permalink) Old 11-28-12, 13:13
the SHO forum say's "465 lbs with all accessories, "ready to run." not including trans, or clutch/flywheel though.
~Patrick~
post #27 of 29 (permalink) Old 11-28-12, 13:59 Thread Starter
zlyricist's Avatar
aw shiet green and gold baby!
i have no ps or ac, so thats probably minus 50 lbs. so lets say it weighs ~400-420ish right now. how much is the f2t weight complete w accessories
wont be hitting the scales til i go to the race track, which might be never haha
1999 626 kl manual
2002 maxima
post #28 of 29 (permalink) Old 11-28-12, 14:28
From all the one's ive moved in and out of cars, and around in my garage. Id say a F2T with accessories is right around 350-400 not including trans. Its not very light when loaded with the turbo and acc's.
~Patrick~
post #29 of 29 (permalink) Old 11-28-12, 23:09
Leev's Avatar
Quoted: 41 Post(s)
thanks for comments
If you are serious, and you do..I would either love to buy one from you or see your plans.
Dirt road rally with the mx6 is fun, but I've always wanted a skid plate...
91' MX-6 LX(T)
Fast stuff: VF12/VJ11 Hybrid/Dual valve springs/Fidanza FW/Maas O2 housing/Mjspiess 2.5 Downpipe/side exit/Walbro 190/Bosh DRI injectors/NGK plugs/wires/MSD B2 coil/ATX TB
Stiff stuff: GC coilovers/PGT rear sway/AWR trailing links/Energy endlinks/Dutch FSTB/RSTB
Leev is offline
