almost... - Mazda MX6 Forums: MX6 Forum
Old 11-10-12, 0:55   #1 (permalink)
  Total: 1118 Power: 5
zlyricist's Avatar
almost...
almost got her back up and running after 3 years
after emissions, i got a magnuson mp90 that ill be putting on
more pics to come once she runs and i get her cleaned up
1991 gt - still busted
1999 626 kl manual
2002 maxima
Old 11-10-12, 2:53   #2 (permalink)
  Total: 552 Power: 5
chief tool's Avatar
Madness!
Old 11-10-12, 10:11   #3 (permalink)
  Total: 1951 Power: 6
Zach's Avatar
holy shiat! I'm about to get mine up and going as well...just need a couple more dry days
88 626 4WS Turbo Noble White
97 626 LX V6 Timberline Mica
Email me for a turbo rebuild!
Old 11-10-12, 23:28   #4 (permalink)
  Total: 524 Power: 5
Does the hood close yet? Last pic I saw the hood wouldn't close.
Teh Telstar can NEVAH lose!
Old 11-11-12, 10:51   #5 (permalink)
  Total: 480 Power: 5
It looks like all the support bracing has been cut off the underside of the hood. Probably did that for clearance.
And hell yea! its nice to see a pic of a 1st gen project on here instead of all 2nd gens like its been.
monoxidechild is online now   Reply With Quote
Old 11-12-12, 11:16   #6 (permalink)
zlyricist's Avatar
yea the hood closes. having trouble getting the driver side axle to stay in. i dont know if the clip isnt holding in there or if the angle has changed so slighty enough to where it doesnt want to stay... i can get it bolted up snug but once it rotates it pops out
it doesnt seem like there is much support up on the sho forums for wiring in the engines, only a few people know whats up. and the people that do, have the info for the 3.2 and not the 3.0 like i have. the good news is after this weekend i have spark but cant get the injectors to fire, it still dont have a maf or clt sensor. though i have read that the stock ecu doesnt need that to start and idle
1999 626 kl manual
2002 maxima
Old 11-12-12, 11:39   #7 (permalink)
Zach's Avatar
Do you want a "bible" and spare engine harness with EECV? It's for the 3.2, but the nominal differences are pulley's and bore. Electronics are the same between the two.
Old 11-12-12, 14:40   #8 (permalink)
zlyricist's Avatar
i could take a look at the bible if it is online?
ive got to be just missing a signal or two
im using the stock mx6 body harness which has all the relays i need really. so im not using ford's CCRM to run the relays. well i think that is where i am failing. i think the AC stuff, or clutch position or, maybe fuel pump needs to trigger something in the ecu to fire the injectors. will hopefully figure it out soon!
1999 626 kl manual
2002 maxima
Old 11-12-12, 14:56   #9 (permalink)
Zach's Avatar
When I was planning to run my SHO, I was planning on using the SHO harness, EECV and Relay Box. It has all of the controls
I'm surprised you aren't trying to run this with MS I think they actually sell an EECV replacement with MS
Old 11-12-12, 19:26   #10 (permalink)
zlyricist's Avatar
i will tackle the ms thing or use tweecer once i get her to pass emissions. then once she runs on that, ill pluck the engine for some blower action
i finally found some legit wiring diagrams!! i should have it running by the end of this week
1999 626 kl manual
2002 maxima
Old 11-12-12, 19:40   #11 (permalink)
Zach's Avatar
awesome! unfortunately what I have is in paper form and is a HUGE book
Old 11-20-12, 21:53   #12 (permalink)
  Total: 263 Power: 5
jphillips626's Avatar
Sickness! LOVE for the YAMAHA engine!
Noble White 626 turbo 4WS 5spd.
http://www.cardomain.com/ride/2525741 SOLD
91 626 Hatchback turbo LEATHER// 88 626 Hatchback 5spd N/A Daily Driver
91 LE 626 Project // Coming Soon Another SHO 626
jphillips626 is offline   Reply With Quote
Old 11-24-12, 0:22   #13 (permalink)
zlyricist's Avatar
she lives!!! runs like crap and leaks oil from rear main seal....f f f fail! its a pretty bad leak, though id like to pass emissions before i go through the effort of pulling the engine again. we will see. i had no clutch and the car went into all gears while it was running?
so anyways, long story short. i found out i had a bad ecu. now i need to find out if it has bad sensors/dis/needs tune up. will update when i have somethin good to report
1999 626 kl manual
2002 maxima
Old 11-26-12, 0:43   #14 (permalink)
  Total: 10 Power: 3
what engine is that..
Digital is offline   Reply With Quote
Old 11-26-12, 13:46   #15 (permalink)
  Total: 10 Power: 0
VULCAN engine iirc
MX-6 GT 88 is offline   Reply With Quote
