Slave/Clutch Issue - Mazda MX6 Forums: MX6 Forum
Old 11-10-12, 9:44   #1 (permalink)
Slave/Clutch Issue
Replaced clutch slave and master one year ago. Yes, I used cheap advance parts because I was unemployed (and will be again next week) The GT has 210,000 miles and now the clutch has stopped working again. The fluid was black and after changing the fluid and bleeding, it's still not working and the fluid is black again. My questions are, can the slave be bad and not be leaking?
Also, is the rubber line still available from the dealer or aftermarket? When I was bleeding it last night (with a mityvac) it didn't seem to flow fluid like it should...
If I have to replace everything who has good parts anymore (at a reasonable price) Someone mentioned buying a slave from Mazda, but haven't those parts been sitting on the shelf for 20 plus years?
Two more hours of this play, somebody shoot me!
Abraham Lincoln
http://www.timewarpvmc.org/
slime is offline   Reply With Quote
Old 11-10-12, 12:18   #2 (permalink)
  Total: 135 Power: 5
Scatman95's Avatar
Rock Auto, great prices and u get a magnet with every order. I order many things from there, and i think someone just posted a new 5% discount code that u can use.
Corksport or RR racing( i think) offer stainless steel clutch hoses
95LS-ZE ATX The redheaded step child
97LS: Sold, she'll be missed
03 WRB WRX: the daily, Stage 2 Clark tune
95 LS-ZE MTX and LSD equipped
Scatman95 is online now   Reply With Quote
Old 11-10-12, 15:40   #3 (permalink)
Thanks. Unless they have something that will interchange, Corksport doesn't have anything for the 1st gen MX-6, but I'll check.
Abraham Lincoln
Old 11-10-12, 16:20   #4 (permalink)
  Total: 135 Power: 5
Scatman95's Avatar
Sorry i was on my phone when i sent that and didnt see the forum section.
Neither of those websites have clutch lines.
Old 11-11-12, 10:54   #5 (permalink)
  Total: 480 Power: 5
the clutch line on your 1st gen is the same as the clutch line on any other FWD mazda made in the last 30 years. You could order one for a mazda6, and it will fit.
just order one for a 2nd gen mx6 and you will be fine.
Old 11-11-12, 14:47   #6 (permalink)
Are you talking about the rubber hose? I replaced the slave, but still nothing..
Hose and the master next..
Abraham Lincoln
Old 11-11-12, 23:42   #7 (permalink)
  Total: 480 Power: 5
yes, the hose. I was talking about what you can order as a stainless steel replacement.
Old 11-12-12, 17:02   #8 (permalink)
  Total: 31 Power: 5
I replaced probably 8 or 9 slaves in a period of about 3 years, and two master cylinders. In short time the fluid would always turn black. I used "good" quality Raybestos parts, cheap offshore parts (they were absolutely identical), tried a different brand of brake fluid... they still failed predictably.
Then I changed the black rubber flex line, and it hasn't failed for 2 years - the longest time yet. I also changed from cheap brake fluid to Valvoline. Probably they are the same, but I suspected that the cheap stuff was in part to blame.
You have to get the system absolutely clean - so blow compressed air through the metal lines to blow out all the old brake fluid and abrasive particles.
I became very good at driving without a clutch. It makes stop and go traffic challenging.
X6driver is offline   Reply With Quote
Old 11-13-12, 11:44   #9 (permalink)
  Total: 138 Power: 5
If you have a fresh slave and freshly-black fluid, your master is toast.
1989 MX-6 GT. ORIGINAL OWNER!! 300K on the original clutch, K&N drop-in, Gillis boost valve, Tokico Blues, OEM RSTB, Energy Suspension poly sway bar bushings, end links, tie rod end boots, AWR poly motor mounts, OEM rear lower tie bar, PGT rear sway bar. Techna-Fit stainless brake lines, AWR trailing links, new OEM lateral links.
mlp-mx6 is offline   Reply With Quote
Old 11-13-12, 13:45   #10 (permalink)
  Total: 480 Power: 5
Or the rubber line is degraded, and causing the fluid to turn black from the rubber breaking down internally. Ive had this happen to me personally.
