89 mx6 gt 4ws trouble starting - Mazda MX6 Forums: MX6 Forum
Old 12-7-12, 11:33   #1 (permalink)
  Total: 10 Power: 0
been looking and haven't found anything like my problem. when it's cold it won't start, it will run for maybe 3 seconds then if i keep cranking it nothin, but if i turn if all the way off and try to start it again same thing run then die. it will die something when im driving but it will kick back on and be fine.
here what i did so far
-check codes and have code 1
-fuel filter
-fuel pump
-check spark when it dies and still have spark
-good fuel pressure
ahfaulk is offline   Reply With Quote
Old 12-7-12, 11:49   #2 (permalink)
  Total: 94 Power: 5
Have you checked the fuel transfer pump and control unit? The shape of the 4WS fuel tank requires two pumps; the main supply pump and a transfer pump. You might be low on the main pump side and the transfer pump isn't kicking in.
Currently driving: 01 F-150 7700 XLS (daily driver)
Project: 89/90 MX-6 GLX hybrid
chrmar is offline   Reply With Quote
Old 12-7-12, 16:24   #3 (permalink)
  Total: 10 Power: 0
i can here both pumps working. would that pop on the check engine light? if i un-plug the fuel pump when its running its not the same reacion, that more of a stumbling and that doesn't pop on the light
Old 12-7-12, 19:14   #4 (permalink)
  Total: 1951 Power: 6
Zach's Avatar
I believe code 1 is for distributor signal. have you swapped distributors? It could also mean that you have a no fire event, so possibly stock igniter is going bad as well. If those don't fix it, then likely you have either a plugged fuel filter or your pump is working, but is not supplying enough fuel.
88 626 4WS Turbo Noble White
97 626 LX V6 Timberline Mica
Email me for a turbo rebuild!
Old 12-8-12, 13:20   #5 (permalink)
  Total: 10 Power: 0
I was going to so the distributor but wantet to be more sure what it was
Old 12-8-12, 19:28   #6 (permalink)
  Total: 10 Power: 0
ok so driving home it died light came on and i have a code 17. looked up the code and there is no 17 or even a 7
Old 12-9-12, 5:27   #7 (permalink)
Zach's Avatar
could be code 16 for EGR.
Old 12-14-12, 17:32   #8 (permalink)
  Total: 55 Power: 5
blackmx6's Avatar
might be the dreaded code 1 no spark code. never found a solution to that one, good luck.
if it's code 16, just take your egr valve off and clean it with carb cleaner. ive had mine do that and it cleared the cel off and it worked fine.
_Zoom____----=+_.''/_|__d>____
RIP SixSick6
Old 12-14-12, 20:29   #9 (permalink)
Zach's Avatar
It's easy...distributor, igniter or ECU.
Old 12-14-12, 20:35   #10 (permalink)
  Total: 10 Power: 0
i got a dizzy and igniter on about a week ago now and no problem seems to be fixed
