Need to pull one from my 89 and stuff it in the 88. I have keys for both cylinders. What would the process be to swap / salvage one for the other, and keep both of them working?
I'm assuming the wsm doesn't have this info lol. Thanks.
Swapping the ignition cylinders is a simple enough process. Are you looking to swap them out or are you rebuilding one?
To remove them you'll need to cut notches in the bolts as they are security bolts that lose their heads when you torque them down. A die grinder works great to cut a notch and then you can use a flathead screw driver to get them out. You'll obviously need to remove the column covers to do this. Unplug the harness from the back of the cylinder, unscrew the bolts and the cylinder comes right out. If you don't care about security (no one will see the bolts under the cover anyway) just reuse the bolts when putting the 'new' cylinder back in.
I just use vice grips to loosen them and use pliers after that.
I have also drilled two small indents in the top and used one of those two prong security bits in the end of the driver.
You can also drill a hole in the top and use an ezy-out.
Its one of those things where it depends what tools you have as to to what's the easiest way.
I've got plenty of tooling, thankfully. I was wondering about any key-ways or the push-in style lockouts like most American cars have on their key cylinders.
Sounds pretty straight forward though, just a couple screws and they slide right out? I want to do this to eliminate the potential failure i'm having on the new car. I did some searching and chief tool's posts about cylinder failures has me thinking that's where my troubles are, probably. Then since the new car only has the valet key, i could swap door and trunk cylinders from the 89 and just have the true master key for all locks / ign on the newer car. Might sound like a bit of work, but not too much work to get the reliability i'm after.
I need to do some work on the 89 interior door areas anyway, one ext handle is snapped off and a window motor is clunking and stuttering like crap on the window upward motion. Ah, the joys of poorly lubricated stuff with these cars.
That one wont be fixed with lubrication. It sounds like the plastic gears are worn out. They could have worn out due to the glide strip having worn through on the window channel, which has increased the effort needed by the motor to slide the window glass up and down.
I spent a fair bit of time working on this problem and I don't think I was ever able to fix it completely as I was working with second hand parts. With new ones it might have been possible, I didn't have access to them.
In some ways I like my GC better as it uses a conventional window regulator with a motor which is all metal. The window channel is the conventional bailey channel, easier to fix and lasts much longer.
Understood completely - i have a motor and rail ready to throw at the issue.
It's not the end-all because if i cannot get it fixed i will just continue to manually assist the drivers' window up. I will already be inside the door replacing the ext handle.
