Water Pump O-Ring - Mazda MX6 Forums: MX6 Forum
Old 2-17-13, 15:29   #1 (permalink)
  Total: 10 Power: 0
Question Water Pump O-Ring
Hello,
After reading almost all of these forums on "water pump replacement" i have found no answer for my question. Im looking for the location of where the "rubber o-ring" goes on the water pump on my 90 N/A mx6. after removing the pump, there was no o-ring to be seen. Any help or pics would be really appreciated as i need to get this thing back on the road in less than a day. THanks!
1G90MX6 is offline   Reply With Quote
Old 2-17-13, 15:29   #2 (permalink)
  Total: 10 Power: 0
And not only that, but half of the pictures that seem to be attached in the forum dont seem to load on google chrome for some reason.
Old 2-17-13, 19:25   #3 (permalink)
  Total: 94 Power: 5
Chances are those pictures are very old and no longer exist.
According to the WSM there are no o-rings required on the water pump. I don't remember having to use one when I did the same replacement.
Currently driving: 01 F-150 7700 XLS (daily driver)
Project: 89/90 MX-6 GLX hybrid
chrmar is offline   Reply With Quote
Old 2-18-13, 1:28   #4 (permalink)
  Total: 552 Power: 5
chief tool's Avatar
The only O-ring I know of goes on the heater return pipe
Old 2-18-13, 9:25   #5 (permalink)
  Total: 1710 Power: 5
Ive had a few replacement water pumps that came with an o-ring. They have a machined recess where the o-ring seats so it seals to the block. I think nowadays they are mostly an odd and somewhat rare item.
If yours does not have an o-ring, then it uses a metal compression gasket (some replacements will include a fiber gasket) to seal things up.
Good luck
Gavin
Old 2-26-13, 19:20   #6 (permalink)
  Total: 10 Power: 0
Thanks for the feedback. Completed my engine rebuild, and all started up nicely. Just having some idling ups and downs and whirring from the water pump area.
