Well speaking from experience, I've never had one pop out on me(knock on wood). I revcently changed one(drivers side) and I had it pressed as the whole control arm is way too pricey for me. SHANNONLUJAN, I would also recomend if you go the "press" route that you have it mig or tig welded, just 3 tacks not beaded or anything, this ensure that IF it decides to try and walk out it can't, and also with just the tacking IF you need to remoive it again you can simple grind down the spot weld and remove it fairly easy. Oh and BTW now it sound like my passenger side front needs to be changed now, DAMN it seems to never end, oh well I still love my 6.
