Sure, try something else. There are many reasons it may not be getting spark. Plugs, wires, disty cap+rotor, disty itself, ecu. Have you checked any of these at all? Could you also describe what happened and is happening when you try to start it? That will help us help you diagnose it.
Tommy ~ 88MX6GT ~ HybridMX6 ~ BoostedMazda (I have too many names)
1998 Ford F150 4x4 Supercab Longbed - Stock and stayin that way.
Check your ECU codes... if you're throwing the crankshaft position sensor, it may be your disty, or at least the sensors inside. I've been through it before... changed the cap, rotor, plugs, wires, coil, igniter, and in the end, all I had to do was take apart the distributer and clean the sensors with alcohol
1990 mx-6 won't start
I HAVEN'T CHECKED THE DISTRIBUTER YET, BUT YESTERDAY I CHANGED THE YELLOW RELAY THINKING THAT WAS IT AND IT WASN'T.TODAY I WILL CHECK THE DISTRIBUTER WHEN I GET HOME FROM WORK.
