Code 05, coughing sputtering, black smoke - Mazda MX6 Forums: MX6 Forum
Old 1-15-04, 16:25   #1 (permalink)
  Total: 986 Power: 5
Well I got my new motor swapped in after blowing the old one up with a 175 shot. This motor is a '92 PGL motor with 117k but ran perfect ( Yes, it's an n/a longblock)
Anyways, at first the car refused to start. After messing with some vacuum lines and connections I got it sputtering along but I had to rev the hell out of it to keep it running and its just pouring black smoke out the exhaust. The only code I'm pulling is 05- Knock sensor. Could there be a connection between this code and the car running so bad? It's running terrible, not even good enough to move the car more than 10 ft.
01 Yamaha YZ250
Old 1-15-04, 17:15   #2 (permalink)
  Total: 12 Power: 5
i thought the n/a longblocks don't have a knock sensor.
sooooo you are puting a n/a block into a gt w/turbo etc. did you change the distrubitor too or did you keep your old one (gt)?
drdemux is offline   Reply With Quote
Old 1-15-04, 17:17   #3 (permalink)
Jon
  Total: 1205 Power: 5
Did you move your GT knock sensor over to the NA block? I assume you moved your GT intake manifold over, and are running everything off the GT ECU, with the GT distributor right?
If not, your problem is probably trying to run it with the LX distributor, change all that out.
Old 1-15-04, 20:05   #4 (permalink)
  Total: 986 Power: 5
I'm using an n/a longblock. I'm using all my GT sensors, manifolds, and even swapped over the oil filter thread pipe so I could fit my oil cooler on the n/a longblock, as well as the oil pressure sending unit and knock sensor off my GT. I'm running a GT ditsy, and have switched between 2 with no luck.
The ONLY thing I can think of is that sensor, like maybe the car thinks it;s knocking and is going into a super rich safe mode. I've looked over everything more than once and killed my battery 3 times cranking it over.
01 Yamaha YZ250
Old 5-16-05, 14:15   #5 (permalink)
  Total: 530 Power: 5
I'm having this exact same problem after I R&R my cyl. head. It idles fine (~1000 rpm) but when you boost, it sputters like crazy. I did a fresh tune-up, new plugs, wires, cap, rotor, even changed the distributor out. I get a CEL when it sputters, and I pulled a code 05 - Knock Sensor. The connectors for the knock sensor is connected. Oh, when it sputters, the tach goes crazy (jumps up and down)...Also The firing order is correct 1-3-4-2...
I pulled out the brand new plugs (gapped at .040) after a short boosted run and they were black. I can't imagine my knock sensor taking a [shizzle] after R&R of the head.
Rebel, did you ever figure it out?
1989 MX-6 GT - SOLD
T3/T4, MegaSquirt 'n Spark
cenatix is offline   Reply With Quote
Old 5-17-05, 16:58   #6 (permalink)
  Total: 530 Power: 5
Anyone have any insight on this problem?
1989 MX-6 GT - SOLD
Old 5-18-05, 1:48   #7 (permalink)
  Total: 986 Power: 5
I did fix it a few days after I started this thread. Turned out to be a loose hose clamp causing unmetered air to enter the intake.
It was weird though, I never pulled a VAF code. Also, after a few resets the knock sensor code went away.
01 Yamaha YZ250
Old 5-18-05, 12:42   #8 (permalink)
  Total: 530 Power: 5
I fixed the problem. Turned out the ground by the distributor was disconnected.
1989 MX-6 GT - SOLD
