Originally posted by 88 626 2.2T
Power flow should be clutch plate, input shaft gears, sliders/syncros, counter shaft, pinion/ring gear, and then diff spider gears and out the cv axles. Shreaded themselves? No I think he poped the clutch in gear and sheared those teeth off. Are the spiders blown up? dont know ask Dutch to post us a pic.
Not recognizing that the diff pin was welded, I figured something might of sheared off there.
With that in mind, strengthening the gears might be in order. Along with the input shaft, as that was what Jayb took out. Would like to see the spiders, but it seems like those are ok as they are sitting over on the cardboard. Also his case is not "holed" as was seems to happen when the spiders let go.
To do this would require new cut gears, or cryo'ing the current ones. Any ideas?
A cryo of the input shaft should be good unless it is already that way from the factory.
