Over the years I've seen some requests for alternator upgrade options for our cars. I myself have always wanted something a little better than our puny 70 amps. I've discovered some things recently that are fascinating and useful.
While it's common knowledge at ATX GT's came with an 80 amp unit. What may not be known is that 2ndgen 4cyl alternators, which are easily available are also 80 amps and fit with very little modifcation. In fact the only mod needed is to swap your 1stgen pulley on, which requires drilling out the hole to fit the larger 2ndgen alt.'s shaft. That and the positive terminal requires a bigger eyelet. I'm running this setup currently and it works great.
80 amps not enough? Ok. How about this one?
What is it? This is a 100 amp alternator from a FD RX7. Does it bolt on?
You tell me. This is in fact a FD alternator bolted to my FE3. My friend bought it for his rx7, and I told him to bring it over so I can see if it works. It also requires swapping (and drilling) the pulley, and requires the longer FD bottom mounting bolt, but that was about it. It's physically larger than our unit, but fits fine. Belt alignment is spot on too.
Now I have some other ideas if 100 amps isn't enough for you. But I'm going to keep my mouth shut until i can verify it actually works. But if it does, it will be very sweet.
