Old 3-19-07, 15:30   #1 (permalink)
  Total: 10 Power: 2
Manual Windows?
Anyone know where I can get my non-functional power windows in my gt converted to manual crank ones? The power window parts are completely shot and I want windows that work, even if they are manual. Or does anyone have maual window parts?
Thx, Josh
'91 Mx6 GT: Project Paperweight
'02 Protege5: The Silver Bullet
myspace.com/kartrebel81
Road-Rebel is offline   Reply With Quote
Old 3-20-07, 5:19   #2 (permalink)
  Total: 609 Power: 3
carcenomy's Avatar
Unless you're a Gavin and want the lightest AutoX machine in the world evAr, you may as well just fix your power windows. It'd be more effort removing the power window support hardware and installing the manual parts from a DX than it would be to simply fix the power windows
Someone should have some power parts around, and SURELY someone has a DX spare that they can get the regulators, handles and doorcards from. Just remember, downgrading is a drastic step and will involve many parts...
Old 3-20-07, 22:15   #3 (permalink)
4WS Freak
  Total: 251 Power: 5
You probably just need a new switch. I am already on my spare or i would offer you one. Hopefully you can isolate the problem and get her working. Good luck, I'll keep my eyes open at the local wrecker for ya tomorrow when i go.
Noble White 626 turbo 4WS 5spd. Intake, exhaust, turbo timer =reliable daily driver.
http://www.cardomain.com/ride/2525741
jphillips626 is offline   Reply With Quote
Old 3-22-07, 0:01   #4 (permalink)
  Total: 10 Power: 2
Thanks. But I'm pretty sure it's the whole motor assembly. I've had the door skin off and the little ball/link things were slipping (making the window lurch down when i hit the button) My dad and I fashioned a way for them to work pretty smoothly. but now it's completely dead.
I now have 2 options here. I can keep the car, fix it,and sell my new racing kart (pics on myspace link) or keep the kart and scrap the car. I love the car to death but it is just so far gone. Too many things to list. It would cost more to keep/fix the car then to race/maintain the kart sooo.... I'm prolyl gonna get another car. I'd liek to get another 6 but i don't know...
Thnx again for teh help.
Old 3-22-07, 12:39   #5 (permalink)
  Total: 824 Power: 5
Thx, Josh
Just swapping the mecanisms (auto/manual) is easy, finding door panel and window handles that match you interior, getting them shipped, or even just buying them is more trouble .....
Just get the assembly from any 88-92 power window 626/mx6, the brackets are different lenghts but the motor's are the same, so swap the motor, the assembly comes out of the door very easely, (5 (m6) 10mm bolts, 2hold the window and 3 holt the assembly).
You can test the motors/assembly's, just unplug the motor and supply 12v directly to it, (2 long wires from your battery or use a booster pack or battery charger) then reverse the polarity's to change dirrections.
I know alot of members have had switch problems, but most of ours have very slow widows due to old and tired window motors. The 626 motors (front doors) are much faster (usualy) due to the smaller size of the glass they have to move.
Using 12v directly to the motor will rule out or confirm switch problems.
I understand that its the beed track thats slipping, inspect the beeds for damage, it could be the piece that catches them.
[quote=carcenomy;1748271]Unless you're a Gavin and want the lightest AutoX machine in the world evAr, you may as well just fix your power windows. It'd be more effort removing the power window support hardware and installing the manual parts from a DX than it would be to simply fix the power windows
I have a couple of manual assembly's and they are about the same weight and size as the automatic assembly's, the handle and the button pad probably weigh the same, maybe the DX door skin weighs less? the only weigh reduction I could see, would be to pull out the wires runing in the car for the power windows, or you could just spit out your gum before the race.
Old 3-23-07, 4:05   #6 (permalink)
STW
  Total: 422 Power: 3
STW's Avatar
Definitely not worth the effort... just get needed parts for power windows second hand and you're done.
Luckily MX-6/626 window lifts are pretty simple to fix, I had a go on a Toyota Corona window lift and god damn that was one bitch of a job.
626 '88 Wagon, turbo 2.0 DOHC
Old 5-12-08, 14:41   #7 (permalink)
  Total: 18 Power: 1
I'd still prefer to put the manual windows in anyway. Anyone have good information on how this would be done?
surfnaked is offline   Reply With Quote
