Old 11-19-07, 16:56   #16 (permalink)
  Total: 84 Power: 0
So I was helping my friend today with his brakes. He happens to own a 1996 Subaru Legacy. Just to let you guys know, they all don't have two piston front calipers. His were only one piston but he also had drum brakes int he back.
sokarul is offline   Reply With Quote
Old 11-19-07, 20:13   #17 (permalink)
  Total: 341 Power: 3
chief tool's Avatar
If it had drum brakes it was probably only a "Gx" the GTs were the ones with the dual piston fronts.
Old 11-23-07, 21:42   #18 (permalink)
  Total: 341 Power: 3
chief tool's Avatar
Found some
thanks to crazyone who put me onto a memeber of the liberty(legacy) forum here in Oz....I picked up a pair of calipers after he did the 4 pot upgrade on his Liberty.
He said they came off a 93 model....and that apparently the 94-99 WRX ones are the same. I dont know whether that applies to all models around the world, but it may be the case in Oz and maybe the JDM...
Old 12-2-07, 20:32   #19 (permalink)
MX6.com Supporter - Click Here for Information Meister Mechaniker
  Total: 131 Power: 2
Keeloh's Avatar
I went to the junk yard today and found a 91 Legacy with dual piston calipers score them for 30 bucks
91 Lx to GT Swap/T-Bird Turbo/Zebel Housing/2.5" Downpipe,Test Pipe,Sebring Exhaust/Probinator Chip/15psi/Walbro 255LPH Fuel Pump/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Fidanza Aluminum Flywheel/Exedy Clutch/AWR Mounts/AWR Trailing Arm/GT Rear Disc Conv/Subaru Front Dual Calipers/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats with 4 point Harness.
Old 12-3-07, 11:10   #20 (permalink)
  Total: 84 Power: 0
Apparently it's actually the "L" model.
Old 12-8-07, 14:56   #21 (permalink)
  Total: -13 Power: 0
just got some 96 legacy wagon dual piston calipers today at one of my local u-pull junk yards and they fit directly on my 90 mx6 gt. i tried them on another mx6 there at the yard and you have to get the pins from the legacy for them to work, the brake line bolts right up and the lower 14mm bolt from the mx6 or legacy will work. the slider pin is about 3/4 of an inch longer. $20 for both
GABRIEL
MAZDASPEED505 is offline   Reply With Quote
Old 12-11-07, 2:07   #22 (permalink)
  Total: 690 Power: 0
No, you dont actually. Ask me how I know.
Old 12-12-07, 23:30   #23 (permalink)
  Total: -13 Power: 0
the brake lines needed minor work to fit but every thing else worked perfectly! i am sure the slider pins from the mx6 might work but i would rather put the proper ones on my car! i am not gonna take the risk of them being to short so?????
GABRIEL
Old 12-13-07, 1:13   #24 (permalink)
  Total: 690 Power: 0
Soooo that still makes you wrong. The mx6/Probe pins work fine. And I never had any problem with the brake lines
Old 12-13-07, 21:04   #25 (permalink)
  Total: -13 Power: 0
my driver side brake line would not thread in so i had to grind a hair bit off the little guides on the calipers for them to start to thread in
GABRIEL
Old 1-11-08, 22:00   #26 (permalink)
So, we're still using our stock or a/m rotors with the Subie calipers? Anyone tried a different setup with a larger rotor and caliper assy? I'm looking for an inexpensive alternative to this weak*ss brake system we've got! Also, any mods to the rear would be helpful.
sixgun is offline   Reply With Quote
Old 1-12-08, 1:48   #27 (permalink)
  Total: 341 Power: 3
chief tool's Avatar
Yeah there have been some posts about this very subject in the last week or two, there is one based around an upgrade to Honda 300mm rotors, and a couple more using mitsubishi parts and 4 pot calipers....the threads are pretty easy to find.
