Old 1-13-08, 19:01   #1 (permalink)
  Total: 10 Power: 1
fuel manafement system question
well i just bought my car yesturday and the guy who owned it before me put on a aftermarket fuel system and now the car is starving for fuel... im not sure why??? since i dont know much about the car or the mods that have been done to it yet im not sure where to start.
could someone tell me how to adjust the air/fuel mixture or anything else that may help?
i will post photos of the system as soon as i can, i realise its hard to figure out a problem when you cant see what you need to help someone fix.
thanks guys,
Chad
c.bakken is offline   Reply With Quote
Old 1-14-08, 17:09   #2 (permalink)
  Total: 77 Power: 2
Congrats on the new car, what did you get?? I personally have no experience with external FMS but I'm sure it would help the group to know what BRAND of FMS is installed as well as any model numbers.
If you can ask the PO, ask all of this information as he'd be more up to speed on how to adjust the system than anyone else, providing he knew what he was doing when HE installed it.
91GTTurbo is offline   Reply With Quote
Old 1-14-08, 23:01   #3 (permalink)
  Total: 10 Power: 1
sorry i forgot to include what kind of car it was...
its a 90 mx6 gt.
i dont know the brand of the set up and i could tell just by the way the guy was talking about it he had no idea what he was doing...
Old 1-14-08, 23:10   #4 (permalink)
  Total: 420 Power: 5
before offering any ideas/solutions i would like to ask what leads you to the conclusion that the car is starving for fuel?
KITTED 92 MX6 GT<-CLICK HERE
SUPPORTER OF P.E.T.A.....ANIMALS FEEL PAIN TOO! B KIND 2 ALL BEINGS
Quote: Originally Posted by Mr.JasonBH"150MPH Is what I hit."
Quote: Originally Posted by SD6 "A crackpipe is what you hit."
1FIERCEGT is offline   Reply With Quote
Old 1-15-08, 0:05   #5 (permalink)
All aboard the B& V&
  Total: 1693 Power: 5
Zach's Avatar
Came here to say this.
Old 1-15-08, 0:38   #6 (permalink)
  Total: 10 Power: 1
its almost sounds like its missing. and i know that on my street bikes they are most of the time running lean. the car may be different though.. i dont know. please. correct me if im wrong.
Old 1-15-08, 0:47   #7 (permalink)
Zach's Avatar
Like a stuttering? I would check/replace your spark plugs, wires, disty cap and rotor. I would also check your charge pipes and throttle body boot for cracks. Take off all of your pipes and visually inspect/bend/manhandle all the rubber pieces to see if you find any cracks.
Old 1-15-08, 23:58   #8 (permalink)
  Total: 10 Power: 1
yeah like a harsh shutter feeling.
ill check all that.
thanks.
Old 1-15-08, 23:59   #9 (permalink)
Zach's Avatar
tell me one thing...does it stutter only under boost?
Old 1-17-08, 20:26   #10 (permalink)
  Total: 10 Power: 1
thats actualy another problem. it wont build boost at all.
Old 1-17-08, 21:10   #11 (permalink)
  Total: 485 Power: 5
then you have a vacuum leak
1992pgt.. http://www.cardomain.com/id/ademan
1991pgt..http://img525.imageshack.us/my.php?i...wcar002jn7.jpg
Old 1-17-08, 21:43   #12 (permalink)
Zach's Avatar
Or very crappy plug wires. I had this problem...I would only build 4-5psi until it would studder and not build any higher. I had a boot that was cracked in half.
Old 1-18-08, 16:20   #13 (permalink)
  Total: 10 Power: 1
vacum leak? where should i ckeck for it? i dont know anything about boosted engines so when it come to the turbo im completely lost.
Old 1-18-08, 20:32   #14 (permalink)
  Total: 43 Power: 4
any rubber hose or boot in the engine bay that holds vacuum....throttle body boots...vacuum lines on the throttle body...stuff like that
whatnow757 is offline   Reply With Quote
Old 1-20-08, 13:18   #15 (permalink)
  Total: 179 Power: 2
seems like 90% of the time its the throttle body boot. I know mine has a small crack in it (n/a). I'm not really trying to push power at the moment so i dont' care so much about it but take of your boot and check it out and see whats the dilly-o
'74 Kawasaki S1-C 250 Triple 2 stroke
'75 Honda CB360 with a blowd up engine
YES, 40 dollars S+H used pistons, cylinders, valves, and another cyl head. I can't wait to see this thing live. I've never once actually seen it run before.
