Old 9-2-08, 15:46   #1 (permalink)
  Total: 10 Power: 1
boost controller help
boost controller help.
I installed Joe P MBC according to instruction.
1. Turbo elbow- controller
2. wastegate- controller
and use the adjustable bolt to adjust boost.
However, I am only boosting 7-8 PSI MAX no matter which way I move it.
dont know what I did wrong, if anyone else has had this problem?
note: plugged up all openings of solenoid
black6 is offline   Reply With Quote
Old 9-2-08, 18:00   #2 (permalink)
MX6.com Supporter - Click Here for Information words under name
  Total: 362 Power: 2
compnut21's Avatar
pics?...
89 GT 4WS/Megasquirt/FE3 Needs blinker fluid.
My FE3T Project
89 GT Partout!
Old 9-3-08, 1:00   #3 (permalink)
  Total: 10 Power: 1
just finished running hose between turbo outlet and wastegate bypassing solenoid. Still boostin 7 PSI.
Anyone help?
Old 9-5-08, 10:37   #4 (permalink)
All aboard the B& V&
  Total: 1693 Power: 5
Zach's Avatar
turbo outlet (boost signal) goes into the bottom of the boost controller, the output (side) goes to the wastegate nipple. Please take pics.
Old 9-5-08, 13:42   #5 (permalink)
  Total: 153 Power: 2
Keeloh's Avatar
http://www.mx6.com/forums/california...bo-co-hel.html (bo co hel)
89' Lx to 89' GT Swap/Stock Turbo/Probinator Chip 15psi/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Exedy Clutch/AWR Trailing Arm/GT Rear Disc Conv/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats.
Old 9-5-08, 22:16   #6 (permalink)
  Total: 10 Power: 1
i'll take some pics...
