1) Hydrolic press is spelled hydraulic
2) When you press a pin into a piston, the common practice is to heat the piston- press the pin into place.
You raise the temperature of the metal and it ensures against galling when the pin is install.
EDIT: When did I ever say torch? And how hot do you think it
doesn't get inside the cylinder walls anyways?
