Originally Posted by gavin
Not really surprising that theres a lot of variance. If you think about it for a bit, you have different cars with a variety of different suspensions and weights. Its likely that one chassis will work somewhat well with the (very much NOT tuned to individual chassis) suspension systems out there.
Furthering on with the "not tuned" thought. That would also give you a lot of variance in and out of brands.
Does anyone really think for a second that a company can appear out of nowhere and have over 150+ applications instantly and have the rates/valving tested on all of those chassis? It just doesnt work that way in real world timeframes.
concealer404....FSP eh? Have you compared the Megans with another suspension setup(either on your own car or anothers)? It might be revealing. Not knocking your purchase, but you at least have to quantify your statement a bit.
PS: where do you live by the way?
Gavin
I agree on the KSport sentiments. On GRM, someone found a dyno of their shocks, and it was pretty ugly.
Yeah... FSP. It's like bringing a plastic spoon to a grenade fight.
My motor is really weak, i have driveline lash coming from somewhere horribly. The motivation on this car is a gigantic letdown to the rest of it.
I've had KSports on two of my cars in the past. That was before i really knew anything other than "Man, these look DOPE!!!" And then, i liked them.
Since then, i've driven another Celica with KSports, and it was OK. I'm not sure that i'd want to do much other than street driving with them.
In terms of what i've compared my Megans to since i've gotten them on the same or similar platform....
1) 1988 Celica AllTrac w/ AGX and Ground Controls
2) My same 92 Celica w/ GR2s and Eibach Sportlines (Eccchhhhhh)
3) 1990 Celica w/ Yellows and Ground Controls
Combo 1 wasn't bad. However, i'm not sure how direct the comparison is. It's a heavier car, and i don't think the spring rates were as high as i run. I played with it a little on back roads, and it felt good, but a little soft to me.
Combo 2, Sucked. Moving on.
Combo 3 was very similar. However, i felt that the setup was under-damped. It had a double bounce going on, and when you would level out from a really hard turn it didn't settle as quickly. It also understeered.
Another point to bring up which may completely throw out all my thoughts is that i run far more tire than any of those did, and a higher rear spring rate by a rather wide margin.
Now, i'm no suspension guru, and i haven't had a ton of time for development on my car, i just go with what feels right. It was bought as a non running shell about a year ago and it's been a long hard road since then to get it to even where it is right now. I haven't corner-balanced it, haven't dialed in what settings are the best yet, i've just driven it and actively tried to upset it, and i can't, due to other limitations of the car. I've just been trying to make sure that all the work i've done hasn't left any stones unturned before i tear it back down again this fall to finally put some power to it.
So, i'm completely open to the fact that they may be considered crappy. Besides my personal anecdotes on them, the only other thing that i have to offer is that i've met a few people that absolutely hate KSports and would rather walk than own a car with them installed, that have no problems with Megans.
I got mine for $850 shipped due to an order error. When they become the weak link, i'll look into something else.
I'm located in Indianapolis, by the way. If you're in the midwest (can't remember, sorry
) i'll be up at the Tire Rack event August 22nd providing my motor holds together.
