Old 11-18-09, 11:21   #46 (permalink)
  Total: 59 Power: 2
Oh, i see what he did.
Crap. I wish i had done that, now. Oh well. We'll see how bad it is with the new pads and front rotors.
1992 Celica GT F-Prepared
1993 Escort GT ST
1990 MX6 GT Turbo The DD. Supra CT-26 50trim, 440cc injectors, Aeromotive AFPR, Walbro 255lph, Greddy Profec B, Greddy Type S, Tial 38mm, fmic, 2.5" ic piping, 3" side exit exhaust, probinator chip, Innovate LC-1, 2g GR2s/Megan Springs. (LOW)
Old 11-19-09, 3:24   #47 (permalink)
  Total: 1662 Power: 5
define "skittish".
I use my POS daily driver as an example again as a car that simply _works_. No magic, it brakes straight and true and is pretty much unflappable. If that car works, no reason why yours shouldnt work at least as well.
Again, the reason I tried the 2nd gen M/C had nothing to do with the stock or Subaru calipers. The 2nd gen M/C adds nothing to those systems (and actually detracts). In the end I abandoned the use of the 2nd gen M/C as it didnt function in the way that I was hoping it would and (as said) made the rest of the system worse.
Gavin
Old 11-19-09, 9:02   #48 (permalink)
  Total: 59 Power: 2
Originally Posted by gavin View Post
define "skittish".
Gavin
The rear end feels REALLY light under braking, nose dives like crazy, just feels like it's braking only with the front brakes, which pretty much mirrors what you experienced with your car before. It's probably functioning correctly, like i said, i'm just used to the Celica, which also has a MUCH stiffer suspension.
The brake pedal feels GREAT, though... nice and hard.
I haven't done any hard braking since the new suspension, so i'll try again and see what i feel once i finish up the little things.
1993 Escort GT ST
Old 11-19-09, 10:44   #49 (permalink)
Er...isnt this a case of "statement of the obvious" (AKA: "no siht sherlock")
You have a celica thats prepped for F-Street Prepared, pretty much everything else is going to feel softer, because it is. Welcome to the real world of stock compliant suspensions not bricklike/buckboard stiff suspensions.
In all seriousness, there are a couple other things to look for in the system...
-As I mentioned, equal compounds in the front and rear are crucial to the distribution of braking forces.
-Struts play a BIG part as well, Monroes, KYBs and the like just aint gonna help you out here. Honestly even Tokico blues are kinda on the "meh" side. Main thing here is rebound control, especially on the rear of the car. A little compression on the front of the car isnt bad as that slows the dive, but the heavy(er) spring will do that well enough. you want the rear of the car from unloading too fast and thats where rebound damping comes in. Slow the rise of the rear of the car, keep the rear tires planted on the ground as long as possible, maximize braking ability.
-alignment is also an easy one, but one shops dont care for or just go by the numbers as long as the machine tells them its "ok". Without much undue wear on tires you can turn an unstable car into a rock and vice-versa.
-tires...aside from pattern/compound (guess what, cheap all weather M/S tires wont yeild braking performance like some decent summer tourers), pressure counts. The number in the manual is a variable that sometimes has to be adjusted to the tire being used. In other words, to get the best performance out of a tire in terms of braking/handling you may need to vary the pressure up to 5psi in either direction depending on the tire manufacturer/construction of the tire. This however isnt the easiest to do as theres no real guideline as to how to apply this.
Gavin
Old 11-19-09, 12:05   #50 (permalink)
  Total: 59 Power: 2
It's probably a combination of the old blown stock suspension and only god knows what pads are on the car right now, which is why i ordered the metal masters...
I'll install the new stuff and see how it feels with a suspension that isn't 20 years old and report back.
I'm sure it'll feel much better. I appreciate the input, this car is so damn unfamiliar to me.
1993 Escort GT ST
Old 11-25-09, 22:54   #51 (permalink)
Shove it!
  Total: 1903 Power: 5
Zach's Avatar
I replaced my rotors and installed new discs and pads and holy [fizzle]ing [shizzle]
I can finally lock up my wheels on drive pavement...even with some heavy ass 18's
pedal feel is stiff as [shizzle] and 'initial bite' is unbelievable.
The only thing that worries me is that after extended periods of hard breaking...is that pedal feel starts to get a little spongy...my guess is that it's because of the 'store' brand brake fluid that I have in there.
Are there any other recommendations for brake fluid with a higher boiling point?
I see you trollin I be ragin
Parting out Gray 89 GT
Originally Posted by Kansas
Old 11-26-09, 1:07   #52 (permalink)
  Total: 431 Power: 5
gavin uses ate superblue or type200
My IHI turbo page
Old 11-26-09, 1:34   #53 (permalink)
Shove it!
Zach's Avatar
I wonder if switching to braided lines would help this, or if it indeed is just a fluid issue? My lines are fine...not bloating, cracking or anything.
Old 11-26-09, 5:28   #54 (permalink)
Maybe now you know why I roll my eyes when people talk about the "weak" brakes they have and how they need a big brake kit. Cue eye rollie icon...
Its not the brakes fault that you keep it in piss poor condition and feed it a steady diet of substandard parts
"you" being the "royal you" of course.
As mentioned, I like ATE superblue/Type200. Its kinda up in the "elite" ($$$) brake fluid realm (Neo, Motul, Castrol SRF, etc) but its more rounded and practical for even a daily driver. Cheaper too. The local store here carries it so its also a nice convenience. For something more widely available and a little less exotic try Valvoline syn-power. Very good wet/dry boiling point numbers and available at tons of retail chains.
Change the brake lines to aftermarket braided lines if you havent already. They are getting close to 20yrs old now and have gone through _thousands_ of expansion/contraction/heat cycles. Change them, theres really no reason not to especially when a set of braided lines are cheap.
I want to mention some thoughts on philosophy and technique for a sec....
My philosophy on performance is something akin to "performance through product selection and/or rigorous maintainance".
Sure, pimpy stuff is nice, but without maintaining them..whats the point? Also, pimpy stuff tend to need more upkeep at times, but what I tend to see out in the wild is less upkeep (the notion of longer intervals for motor oils, brake fluid, etc). It smacks of conservation of cash more than anything else.
Castrol SRF is arguably some of the "best" brake fluid money can buy...at $75 a pint it better be. But it has a very short shelf life in a car and needs repeated flushing (sometimes every track session). I see people tripping over their dicks to put the stuff in their street cars on other forums all the time. Why? The name impresses people (I have racecar quality brake fluid in my street car, y0) but the truth is they really cant afford it(or understand the needed maintainance for it) so they ignore it and wind up with junk in their car. Its utter nonsense.
I guarantee you that 6month old valvoline synpower from oreileys/vatozone/pep boys will be better in the end than castrol SRF at 3months. AND It wont bankrupt you to flush on a regular basis. Itll stay fresher because you can afford to keep it fresher and thus offer better performance. Its less impressive/pimpy though, but who the F cares? Cliffs: new and unpimpy > old and pimpy
My rotors are blanks @$20 per. I dont even bother resurfacing them. I toss them when they are low and get another new set. Have fun with cross drilled/dimpled/scalloped rotors that cost $80+ per....that work no better and are really worse overall.
Pads, I dont skimp on because you DO get what you pay for here. I have no issue getting race pads for a track day that cost $300 a set and will only be used for that one day. They will save my life every time I hit the brakes. But I am realistic..I cant expect one pad to be all things all the time. $10 pads from pep boys cant act like race pads. I expect they will be hard as rocks and last forever. They will stop the car(eventually), but I wont complain about their meager performance. Likewise, race pads on the streets would be as pointless as "tits on a bull". They need HIGH temps to be usable, something that really wont happen daily driving. You get the tool for the job at hand. If you get the wrong tool for the job, dont blame the tool.
Techniques...
For brake fluid flushes I take my time. If I am doing large component changes(brake lines, master cylinders, calipers) I usually use a gallon of generic ultracheap brandX brake fluid. I flush the system as thoroughly as I can, usually 2-3times over a period of 1-2 weeks. After than I flush with the good stuff. I want to make sure that all the air is purged from the system and sometimes you need to actually drive the car for things to percolate out. Im going to be doing repeated flushes then...think Im going to be doing that with expensive fluid? F-no, that would be retarded. Cheap and disposable...thats the product to use.
To flush I use a two-man system. The system I use is a variant of a setup I saw in use on a couple Speed world challenge cars and ALMS teams. Its a bit involved, but guess what....its thorough, repeatable and it works. Every time...all the time. I dont use speed bleeders (used to for a bit though), one man setups and I dont use pressure bleeders as I find they have a lot to be desired.
Brake pad bed in is important if you have real performance pads. Even pep boys pads have recommendations on break in periods (though few people read the package to see what that is). When you start getting into performance pads and other exotica the break in becomes even more important. In general the pads need some of the remaining binders and glues to be cooked off so they cant transfer material to the rotors and cause hot spots, brake rotor shudder and all sorts of annoying stuff to make braking inconsistent.
The system that I use is also long and involved but it works(anyone see a reoccurring theme here?). Ive mentioned it before, but the end result is the pads have more consistent initial bite and better wear.
Aside from all of that rambling....."extended braking periods"? 0.o wtf? D00d, where the hell do you live that you have extended periods of braking to be done? Is Parkland like SF or something? My daily commute is over a mountain to get to work and back. I pretty much never use the brakes despite some pretty steep grades and serpentine road.
Gavin
Old 11-26-09, 8:56   #55 (permalink)
Shove it!
Zach's Avatar
Gavin, no parkland is not, but Seattle is and lots of people that do not know how to drive and lots of standing brake stops because of this.
I also take long drives along the many mountain twisties around here, which require braking...lots of it
Old 11-26-09, 10:24   #56 (permalink)
See above. Plenty of mountain roads here as well. Get a car that handles, then you dont need brakes
Gavin
Old 11-26-09, 10:33   #57 (permalink)
Shove it!
Zach's Avatar
Gavin
speaking of...my suspension in the rear is making some creaking noises when I go over bumps and dips in the road
I need to get away from the AAS
Old 11-26-09, 10:41   #58 (permalink)
Gavin
Old 11-26-09, 12:22   #59 (permalink)
Shove it!
Zach's Avatar
pfffffft
I still have my eyes set on doing a koni red setup with coilovers. I'll be coming to you for some long winded discussions later
