#17 (permalink) |
unfortunately, i dont have a digital camera, but I am getting one in a month. I can describe it to you. Okay, pop your hood. Top right, against the big hump that holds the strut. There is a bracket that holds a black box. Its maybe 2 by 3 inches. It has some bumps in it. That is the coil. There are 2 wires going to it through the BOTTOM. One is black, and the other is black with a white stripe. Tap the Black wire (negative) for an RPM reading. Also, your spark plug wires. 4 wires go to the spark plugs, and the 5th goes to the coil on the top. Any more questions post here. I still need the speed sensor wire..........
http://www.cardomain.com/memberpage/653666
Intake, Exhaust, T-bird, 14 psi, 5th and 6th injector, 2 1/4 hard pipes with silicone, Adam Chip, turbo xs type H bov, fsb/rsb/rtb, ported 02 housing/exhaust manifold,walbro 190 w/ rewire, egt/boost/airfuel,, MSD coil/wires, kill switch, 35/20 tint, brembos w/ pbr, hks type 1, sts, redline fluid, poly mounts, no ac/ps, cupholders 198.9 hp 272.7 tq |
#18 (permalink) |
NEGATIVE side of coil.....i just did it....it works. Sorry for the confusion.
#19 (permalink) |
so the negative side of the coil does work the the hks type 1 then? i would have done that 4 months ago when i installed it but i didn't think that we could use the signal off the coil, like on a standard tach. hmmm... i'll go search for the speed sensor wiring, someone pm'd me last night about it.
Owner of another Blown F2T
#20 (permalink) |
found it:
take out your instrument cluster, on the back of the circuit board is a screw with the letters RS on it. Just run the wire with a ring terminal to it and that's your speed wire. in the same post the guy mentioned that the rpm wire could be found in the wiring loom going to the cluster but couldn't remeber which wire it was. |
#21 (permalink) |
thanks so much. I did this today and it works. My screw said R-S W or something. Its copper and right behind the speedometer, you cant miss it. To take out the gauge cluster, you must disconnect your speedometer from the transmission, otherwise you can't move the gauges forward.
#23 (permalink) |
theres an hks turbo timer adapter for our car. get that. if not, its like 3 wires.
p.s. 89 wiring diagram in my sig |
89 GT 4WS/Megasquirt/Zebel o2/2.5" Exhaust/10ish psi
1989 Wiring Diagram PDF Useless crap for sale R.I.P. compnut21? |
#24 (permalink) |
who threadjacks a 5 y/o thread? haha
'89 MX-6 GT - R.I.P 13JUN2008
'03 SRT4 - DD http://www.cardomain.com/ride/3107934 performance parts for 1g still for sale so look here now! http://www.mx6.com/forums/fs-parting...-my-89-gt.html |
#25 (permalink) |
who bumps a half a month old jack to point this out?
#26 (permalink) |
2 weeks for a LOL.. i think worth it haha
#27 (permalink) |
at the time i answered his question, i don't think i even realized it was a 5 y/o thread. lol
