Hks Turbo Timer?
hey, i searched probetalk and mx6 for my answers but i couldnt draw any conclusions. anyways, i hooked up my HKS Type 1 Turbo Timer to the ignition and set bought the ZT-1 Harness too. well first of all the timer wont even stay on when i shut off the car. second it only gives me voltage readings. the directions for it suck and i tried every which way to understand the wiring but i cant :-( can someone enlighten me. also do i have to hook anything up to the ECU? thanx alot.
P.S. it's a 91 PGT |
#6 (permalink) |
did you hook the ground up??
me and my dad had this problem, but i forgot how we solved it. is the E-brake up when you turn off the car. its got to be up for the Turbo Timer to arm, dont put it down untill the timer has shut off the car also. if you put it down the car will shut off. this prevents theft. to get to the options, push the little M button at the top left corner. since you said that its on the voltage meter it will turn off, then push it again then it will tell you how much time its set for. use the right buttons to adjust it, i think the top right one is for increasing the time and the bottom for.......... did you hook up the rpm wire, i didnt hook mine up so no matter what it counts down for the time that i set it for. that could be it, if your not driving the car i dont think it needs to count down. you know what i mean, you just installed it and you want to test it. so you start it for 3secs and expect the car to count down? see where im going?? |
Anyone want a NICE 1G? :-/
#7 (permalink) |
yea...
im sure the EBRAKE was up and i can set it to the different options it's none of the othe options show any readings. the only one that is active is the VOLTAGE. also, i drove my car about 5-6miles to my gf's house and then i turned the car off and everything shut off too. i was like **** still didnt work....i dunno what the hell is wrong with it.
#9 (permalink) |
does it beep when you plug in the harness even with the car off and ground connected? even though you have the harness, it may be possible that you don't have a 12v constant source to it, it may be running off the acces 12v when the key is on, hence when you turn the key off the timer shuts off no matter what.
Owner of another Blown F2T
#10 (permalink) | |
1995 Millenia KLZE engine, 8mm wires, NGK Iridium Plugs, JK Autosports CAI, Shaved key holes all around, Shaved marker lights, 4 12" MTX subs, Panasonic touchscreen motorized flip out deck, screens in the headrest and visors, White 5 Zigen 18" rims, lowered with Eibach Springs.
#11 (permalink) |
hey...
i got everything hooked up. here's the schematics...
http://www.probetalk.com/forums/show...did=1701021030 i just cant get the speedometer/tachometer features working. |
#12 (permalink) |
does the Mx-6 have a speed sensor located at the wheels? If so, how do you tap into it?
http://www.cardomain.com/memberpage/653666
Intake, Exhaust, T-bird, 14 psi, 5th and 6th injector, 2 1/4 hard pipes with silicone, Adam Chip, turbo xs type H bov, fsb/rsb/rtb, ported 02 housing/exhaust manifold,walbro 190 w/ rewire, egt/boost/airfuel,, MSD coil/wires, kill switch, 35/20 tint, brembos w/ pbr, hks type 1, sts, redline fluid, poly mounts, no ac/ps, cupholders 198.9 hp 272.7 tq |
#15 (permalink) |
Tap the positive side of the coil for an RPM reading.....now....about that speed sensor
