Go Back   MX6.com > 2G MX6 (93-97) > 2G MX6 General > 2G MX6 Projects/FAQ > 2G FAQ: Performance
Old 9-24-04, 20:32   #1 (permalink)
  Total: 80 Power: 5
How To:Install Air/Fuel Ratio Gauge
This guide is to give you the information needed to tackle your own Air/Fuel ratio gauge installation.I personally used a Sunpro gauge so the installation or wire colors might be different with others.
*Warning I am not responsible for anything that happens due to using this Guide.Common sense should be used when working with electrical systems*
Parts Needed:
Gauge
Extra Wire
Female Splice adapters
Wire taps
Step one:
There should be four diffent color wires on the wiring harness for the gauge.Mine was White,Black,Green,and Red.Take the red wire and that is to be connected to a 12v power source which comes on with the ignition.I used the power wire that goes to the radio.Also, I used the ground that goes to the radio for the Black wire.
Step two:
This is the step I needed extra wire for.The white wire is to be connected to the lights relay so when you turn the lights on the gauge lights up for night for this i ran the white wire through the fire wall to the bumper side markers and used a wire tap to tap into the orange power wire.
Step three:
I also needed extra wire for this.Take the green wire and run it through the firewall to the 02 sensor located straight down in the middle front of the car n the exhaust downpipe and I used another wire tap and connect the green wire to the 02 sensors black wire.
Step four:
Make sure all your connections are safe and i would recommend using shrink tubing or electrical tape to cover the connection to the 02 sensor just to be safe.
Step five:
Turn the car on and make sure everything is in proper working order and there you have it an easy job done.
Hope this gives anybody the info they needed.
Proud Owner Of a 2007 350z
6MT Nismo Intake,Nismo Exhaust,Avic-Z2
Brembo Brakes,
278.4 @ 6850--250lb torque--11.90 A/F
Jay246 is offline   Reply With Quote
