Old 1-7-08, 15:57   #16 (permalink)
  Total: 327 Power: 5
ZE Power MX6's Avatar
You don't need relay for 35W ballast. I do have a relay, in fact 2 in my setup but that's because I ran 50W ballast and Bi-Xenon.
94 RS - The daily
Zoom-Zoom
Old 1-7-08, 17:26   #17 (permalink)
  Total: 327 Power: 5
UnDeR_FLiP: Here's the Bi-Xenon wiring, I totally forgot about it. This will also work as a regular J-Spec wiring to fix the high beam problem.
PS: Oops, forgot to label, those are 40A automobile relay.
94 RS - The daily
Zoom-Zoom
Old 1-8-08, 10:53   #18 (permalink)
  Total: 1507 Power: 5
Stealth's Avatar
Probablly dont even need the relay for the bi-xenon solenoids. They are small and consume very low power. Less than a halogen high beam in fact.
I would just run the relay for the lows, put a diode on the end of the stock cut off harness, and run the solenoid wires to that. Much easier, less clutter relays and open wire.
Project Silo
CF Dash with TV CHEAP
Stealth is online now   Reply With Quote
Old 1-8-08, 12:21   #19 (permalink)
  Total: 304 Power: 5
UnDeR_FLiP's Avatar
^ I've thought about that also, but apparently the solenoids will burn out...if they are fed a constant 12V. Would putting a resistor in line with the diode work?
-Daryl-
1993 Mazda MX6 LS
Old 1-8-08, 15:15   #20 (permalink)
Stealth's Avatar
I have never heard of a 12V solenoid burning out when constantlly supplied 12V.
The coil which creates the magnetic feild is designed to drop a total of 12 V.
I could maybe see an overamperage burning the solenoid coil up, but you cant really FORCE more flow (amperage) through an electrical component when it drops the pressure (voltage) to 0.
Even in that case a simple fuse would solve the issue.
Project Silo
Old 1-8-08, 15:22   #21 (permalink)
Stealth's Avatar
Double post but taking a second look, even look at the diagram above. The bixenon solenoid is tapped right into the headlight connector.
Project Silo
Old 1-8-08, 18:20   #22 (permalink)
  Total: 327 Power: 5
Yeah you don't need a relay for the solanoid, the 2nd relay is there to re-energize the low beam relay when high beam kicks in.
94 RS - The daily
Zoom-Zoom
