Old 1-6-08, 20:49   #16 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
these ones are ok but that at best
2006 Honda CBR600rr - daily driver/rider and potential death machine
Originally Posted by neptune_51
Who would be stupid enough to quote themselves in a sig?
Old 1-6-08, 21:59   #17 (permalink)
  Total: 1704 Power: 5
KING6's Avatar
I dont like them on a red mx6.. any of the colors that are offered. Here some ideas i was toying with:
I kinda like them with out the clear cover, the clear makes them look to much like a headlight. I also dont like niteshades or tints (maybe on a dark color car) also the clear that went to the tail pictured is now damaged beyond repair. The only option is to make another one
Old 1-6-08, 23:23   #18 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
ewww... those tails just don't work on this car. Just seems like there's too much "going on"
Old 1-7-08, 0:20   #19 (permalink)
KING6's Avatar
they are quick photoshops, the real deal wont look as busy.
I have nothing to lose anymore, so im going to go ahead and continue messing with them
what id like to do is try to fill in the deep spots so tha they are flush with the lens's..
just messin with some ideas.. do you have any?
Old 1-7-08, 1:26   #20 (permalink)
  Total: 189 Power: 4
hmm... how about baking the stock lens off, tint all red, then stick it on the new tails?
Mods: KLZE, I/H/E, Hi-Flow Cat, Steel clutch line, RR poly inserts, ACT HDSS clutch, MX-3 flywheel, Chipped ECU, J-Specs w/HID, K-Sport coilovers, RSTB, FSTB, 22mm Rear Stabilizer bar, Clear side markers
Old 1-7-08, 1:35   #21 (permalink)
KING6's Avatar
I have a spare set of stockers that already have the backs hacked off.. couldnt hurt to try it. I was going to toss them into the trash anyway
Old 1-7-08, 9:38   #22 (permalink)
  Total: 307 Power: 5
UnDeR_FLiP's Avatar
wait, so you had to cut the lens' off?? did you try baking them in the oven and prying them apart with a screw driver? I'm considering a pair of these for my LED retro project as well, but if the only way to get the lens off is to cut them with a dremel...forget it!
-Daryl-
1993 Mazda MX6 LS
Old 1-7-08, 12:07   #23 (permalink)
  Total: 204 Power: 5
The_Evil_Demon's Avatar
Please do not paint the tails red. The chrome looked alot better. Get some of the metallic paint and maybe you can make it a diff color. Black or grey but i wouldn't suggest the red
2000 Regal GSX Clone"SuperCharged", 2001 Ford CVPI 4.6L Swap, 2000 Taurus SES 3.0L Swap, 1995 Mx6 Ls Head Gaskets,
Old 1-7-08, 12:30   #24 (permalink)
  Total: 189 Power: 4
i'd suggest anything but chrome.
Old 1-7-08, 23:25   #25 (permalink)
KING6's Avatar
Yes, I already posted that I tried to bake them the same way that you would with the jspecs, aspecs, fogs and oem tails.
The clear starts to deform (sags into the lens's) if you let them get hot enough so that the glue melts.
I tried them at 250deg, for 5min, and the clear started to bend in the spot I pryed it, I used my hand with a glove at first, then tryed lightly prying with a butter knife. Wich eventually started to make the clear crack around the glued area.
So I heated them longer, same results. So i turned up the temp to 300deg, heated them for 5min more, by then he clear started to deform.. the glue was melted.. but the clear would sag and deform as I pryed on it.
I ended up using a thin dremel wheel (as robii suggested) wich eventually put a crack in the clear.. wich was already deformed so I just ripped the [shizzle] off the light by hand.
oh and btw, they will not be homy chromey id prefer to keep the stockers.. wich I might end up doing anyway
Old 1-8-08, 0:10   #26 (permalink)
  Total: 151 Power: 4
I like that all red tint look. Chrome tails might look better if there was chrome trim on the car.
the phranc is offline   Reply With Quote
Old 1-8-08, 21:52   #27 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
I would like to see the entire taillight all red (a little darker) and 2 horizontal LED bars running the length of the light and in the center would be the running light (obviously dimmer)
For reverse just put one white LED (in the inner corner) per light.
Old 1-9-08, 2:28   #28 (permalink)
  Total: 395 Power: 4
put the lense back on with it all red to see what it looks like king
1996 MAZDA Mx-6 M-edition: KLG4 engine, ported intake manifold, 65mm throttle body, custom intake, 96 Millenia MAF conversion, ss autochrome headers, catco high flow cat, 2.5" exhaust, Vibrant Power1 series turbo muffler, ebay civic short shifter, eibach springs.
Old 1-9-08, 9:58   #29 (permalink)
KING6's Avatar
The clear lense is damaged, I already posted that like 3x. Read
Old 1-9-08, 13:26   #30 (permalink)
No one told me about this
  Total: 104 Power: 5
max626's Avatar
did u try to use your extra stock lens? if so do you have pics of it?
Iam just a regular everyday normal guy.
TT Project.
max626 is offline   Reply With Quote
