Old 5-23-08, 2:45   #1 (permalink)
  Total: 35 Power: 2
Help: need to remove layer of primer
i painted a part of my car, didnt expect some of the paint, clear coat and primer to flyoff and land somewhere else. So now, some parts have a thin layer of primer and unwanted paint and clear coat ... not only the body but also on 1 headlight.
what is the best way to remove this primer and paint? sand with 1000 grit? This is the only solution I came up with .... please advice ...
mrfmx6 is offline   Reply With Quote
Old 5-23-08, 4:50   #2 (permalink)
  Total: 115 Power: 2
use some paint thinner on the headlight. not sure if that will hurt the body though, but might be too harsh. i know other people on here know what to do
Old 5-23-08, 16:49   #3 (permalink)
  Total: 35 Power: 2
thinner dissolves plastic ..even hard plastic .. so headlights are vulnerable ... it may also remove my existing paint and gloss if kept for a while .... so I am not very safe with that ... until there is something like dilute thinner. I know high grit sanding is a definite method ... still thinking if anyone has any other things in mind like you ... thanks
Old 5-24-08, 0:14   #4 (permalink)
  Total: 333 Power: 5
A buffer with some abrasive polish might do the trick. I once used some [shizzle]ty whitening toothpaste to take off another cars paint that hit my wife's door. Worked wonders...smelled nice too...all minty and ish.
Old 5-24-08, 3:47   #5 (permalink)
  Total: 115 Power: 2
Just use enough to take off the top paint. Recently I was dissolving styrofoam and at first I tried using paint thinner but the styrofoam just sat there floating around. Left it there for a good 10 minutes and came back and still floating around. Acetone is the stuff that dissolves it on contact. Maybe a little bit of paint thinner on a rag and then wash it off right away? not saying you should do it, just saying paint thinner isn't that strong... well not as strong as acetone :P
Old 5-25-08, 6:56   #6 (permalink)
  Total: 35 Power: 2
lol ... gotta try the paste man ... wanna get my car mint flavored ......
and bmx ... really didn't know abt acetone .. maybe the thinner i used had acetone mixed .... like ur idea of thinner and washing it right away .. will do that on a test plastic for self satisfaction .. then go on to the headlights ..
thanks for the ideas bros ...
Old 5-26-08, 12:24   #7 (permalink)
  Total: 47 Power: 1
Use mineral spirits. It doesn't affect plastics. It needs a little more elbow grease to get the paint off, but it's easier to save the exisitng paint that you don't want rubbed off...
94 MX-6... Stocker Grocery getter
93 Z24... soon to be 3.4L Twin Turbo!
midnightmekanik is offline   Reply With Quote
Old 6-4-08, 11:45   #8 (permalink)
  Total: 1507 Power: 5
Stealth's Avatar
Acetone is fine for the plastic parts.
Project Silo
CF Dash with TV CHEAP
