How to: HID Fog Lights - Page 3 - Mazda MX6 Forums: MX6 Forum
Old 3-30-11, 13:42   #31 (permalink)
  Total: 10 Power: 4
thx for the write up. am about to instal HID angeleyes and was curious about where to mount that ballasts, since it's a little tight under there. curiosity satisfied. thanks again
duncan1982 is offline   Reply With Quote
Old 4-2-11, 19:03   #32 (permalink)
  Total: 10 Power: 3
Do you have the fogs hooked up so they are always on? or just for your high beams?
Danielism is offline   Reply With Quote
Old 9-25-11, 14:40   #33 (permalink)
  Total: 158 Power: 5
the aftermarket harness actually comes with its own switch so u can run them independently of the high/low beam
going wingless is like "a hot chick with no underwear" -Ryan
mx6ReMiX is offline   Reply With Quote
Old 1-25-13, 8:38   #34 (permalink)
  Total: 10 Power: 3
Can anyone post a link to the wiring harness that was used or something similar?
Old 1-25-13, 8:52   #35 (permalink)
  Total: 48 Power: 3
TwoPedalWarrior's Avatar
This what you need, you will have to remove the 9004 connector and only use two wires. Put new ends on the stock connector, join the two and you are off to the races.
Same setup I have and here is the harness New HID Xenon Relay Wiring Harness w 25 Fuse 40 Amp 9004 9007 | eBay
1994 MX-6 LS Automatic - Hunter Green
What have I done to it? Stuff...
What will be done to it next? More Stuff...
TwoPedalWarrior is offline   Reply With Quote
Old 1-25-13, 14:56   #36 (permalink)
  Total: 10 Power: 3
Thanks for the link. Is that the one that has the switch? It would be cool to use them as drls. And did you have to remove the metal peice inside the light?
if youve seen other foglight mods other then the led turn signal let me know
Old 1-25-13, 15:25   #37 (permalink)
  Total: 48 Power: 3
No switch with this. If you want to do it as the DRL mod, google, there are a couple of How To's on the site. For YOU. Like me, Canada has the DRL to contend with. I have a 94 so i was able to pull out the DRL relay under the hood and voila, with the harness, I have HID DRL with the flick of a switch. Switch being the headlight switch to flip on the indicators.
Here is the link with pix and some details
http://www.mx6.com/forums/2g-mx6-gen...ec-1994-a.html (ESpec HeadLight Installation in ASpec 1994)
Old 1-25-13, 15:30   #38 (permalink)
  Total: 10 Power: 3
Awesome, im running j specs so I can probably just splice a switch in there since the wiring is already cut, I like the idea of having that option. I appreciate the help
