Lets talk wheel spacers - Mazda MX6 Forums: MX6 Forum
Old 3-3-11, 9:37   #1 (permalink)
  Total: 13 Power: 4
Ok so I picked up a set of wheels off a Skyline and had them refurbed + new tyres.
Bolted them on the car but the offset is waaaay different and now they sit too far into the arches for my liking.
Question is, whats the biggest spacers you can fit on standard hub bolts? I'm using tuner nuts btw. If you look at the rears, theres way too much arch showing for me and it makes the car look narrow. Anyone know the largest I can use without needing new studs?
Victor_Fandango is offline   Reply With Quote
Old 3-3-11, 11:30   #2 (permalink)
  Total: 94 Power: 5
Phoenician6's Avatar
5mm is safe.
10mm is pushing it. But can be done.
If you dont get hub centric spacers make sure to center the spacer as much as possible before tightening the lugs. (if you dont you might feel some nasty wobble/vibrations.)
Anyways. No more than 10mm is my opinion.
94 MX6 LS - DD, Headers, K&N,hi-flow cat, Borla,RR Inserts, eibachs, bronze FD's, HR Trak spacers, KING6 Bushings, CFZ shifter bushings, ...amongst other things
1964 k10 - Restore job. Mechanically rebuilt, now on to the body!
2007 Ford Fusion - Kid and Grocery Getter
Phoenician6 is offline   Reply With Quote
Old 3-4-11, 21:51   #3 (permalink)
  Total: 406 Power: 5
ZE Power MX6's Avatar
I run 25mm with my Racing Harts since they are +55 offset, 25mm push them out to be +30 which I think is the perfect offset. The spacers are hubcentric with built in studs.
1994 MX-6 RS -- RIP 1/30/2012
1996 MX-6 M-Edition
1993 RX-7 Grand Touring
2010 Mazda3 Hatch Grand Touring
Old 3-12-11, 19:20   #4 (permalink)
  Total: -2 Power: 0
im currently doing spacers as well with my bbs meshies. i did 25mm in the rear and 15 mm in the front. im pretty sure i have the same adapter as above. only problem is with the 15mm the studs stick out. im looking into shorter ones. i think the studs stick out of the 25mm as well. im currently using universal 5mm spacers in the front and i have the 25mm ones on the rear. with my meshies the hubcentric ring doesnt fit. i have pics in my thread.
http://www.mx6.com/forums/2g-mx6-oth...l-spacers.html (wheel spacers)
jonathan2006 is offline   Reply With Quote
Old 12-9-12, 9:37   #5 (permalink)
  Total: 10 Power: 1
I am on 2003 honda accord rims and they have an offset of 55. how big of spacer do i need to make them flush? and what else will i have to do to make that safe? aka: longer studs etc
94 KLDE MX6 MXT - K&N CAI, 67mm TB, Full 2.5" Mandrel Bent Exhaust w. all SS Parts, Wrapped Headers, and Test Pipe M2 Lowering Springs, Angel Eye Halo Projector Headlights w. 6000k HID Conversion + Fogs, Smoked OEM Tails, Purple Under/Interior/Engine/Rim/Trunk Glow, 16" Enkei Rims, 15% Tint, Blue Painted Engine/Calipers, EGR Delete
pigeon853 is offline   Reply With Quote
Old 12-10-12, 3:22   #6 (permalink)
I knows sumpthin
  Total: 934 Power: 5
Ryan's Avatar
Originally Posted by Phoenician6 View Post
5mm is safe.
This.
However IMHO more offset would look even better. Go for 20mm, hub adapter/spacers will be needed or longer studs and spacers.
A RaceCar Named Carmen
Old 12-10-12, 7:13   #7 (permalink)
  Total: 139 Power: 5
JoeyV's Avatar
Rather than get longer stud, get spacers that bolt onto the car that have additional stud built into them. This puts less strain on the hub bolts and allows you to put hmore aggressive spacers. However, the absolute best thing to do is simply buy wheels with the right size/offset from the start.
Elegance Auto Detailing
Your Heart Beats, Mine Rotates!
JoeyV is offline   Reply With Quote
