Go Back   Mazda MX6 Forums: MX6 Forum > Open Forums > General Automotive > Engine Management > 2G MX6 Engine Electronics and Management
Old 3-11-09, 18:15   #1 (permalink)
  Total: 715 Power: 5
Going Wideband
So Im going to install MS and Wideband,
Thanks to Zach for this product link.
Innovate Motor Sports On-Line Store
I dont know if anyone has used it but I will give a review of it after it goes in.
boarding with my wiener out
Old 3-11-09, 20:24   #2 (permalink)
  Total: 1704 Power: 5
KING6's Avatar
people have used it.
Im using AEM uego, Id say its probaly easier
Old 3-11-09, 21:24   #3 (permalink)
  Total: 577 Power: 5
Chefsp0t's Avatar
I'm using an innovate LC1 with the DB gauge in red LED. Great product.
Edit: My DB gauge doesn't have that weird illuminated innovate motorsports logo on it like the ones on their site do.
AJ, if you use the DB gauge and want any other matching gauges they can be found here.
NORDSKOGINSTRUMENTS.COM
They are the digital street series.
Old 3-12-09, 3:26   #4 (permalink)
  Total: 715 Power: 5
I believe this one plugs into the MS, could I still wire in a seperate gauge since this doesnt come with one?
Edit: Semi off topic has anyone used this?
SSI-4: 4 Channel Simple Sensor Interface
Edit:
Originally Posted by Turk View Post
I just bought an Innovative LC-1. $200. Rig it to a digital volt display and calibrate (as Fredio suggested) and im sweet.
So which gauge
Chef - That site only has one wideband gauge and there isnt even a picture of it.
Wonder how hard it would be to do something like this
Old 3-12-09, 6:41   #5 (permalink)
  Total: 577 Power: 5
Chefsp0t's Avatar
The wideband O2 looks exactly like this.
I just linked that site in case you were looking at the gauge on innovate's website. Nordskog makes their gauge and they have others that match.
Old 3-12-09, 9:18   #6 (permalink)
  Total: 155 Power: 4
Me too, got one on my daily driver sitting on the A-pillar.
Innovate changed suppliers for the gauge recently; the ones without the Innovate logo were made by Nordskog, but they've gone to a different supplier now. Partly to bring the price down, but it also seems Nordskog had trouble keeping up with production.
Matt Cramer
DIYAutoTune.com - Megasquirt, fuel injectors, wideband O2 sensors, and more
Matt Cramer is offline   Reply With Quote
Old 3-12-09, 19:59   #7 (permalink)
  Total: 577 Power: 5
Chefsp0t's Avatar
Mine will be in the a-pillar whenever I do some rearranging of my interior. I have space for 6 gauges now. I think that will be enough.
I will be getting a temp gauge soon because I don't trust my stock one and my laptop battery dies too quickly to keep checking the temp while I am driving the car. What others do you guys use (Obviously boost and probably oil pressure will be used too).
Old 3-12-09, 22:32   #8 (permalink)
  Total: 715 Power: 5
See that is why I was going to do the car-puter with the touch screen.
If I am running MS with this wideband cant I just monitor it on the screen and not get a gauge?
Old 3-12-09, 22:37   #9 (permalink)
  Total: 577 Power: 5
Chefsp0t's Avatar
Yeah you can. That was my thought process exactly when I looked at them. Times have changed for me though.
Old 3-13-09, 3:57   #10 (permalink)
  Total: 715 Power: 5
so i read up on the process to wire it into ms. since radars ms is going to a good home he ran wideband too. so the harness should be ready for it.
edit: i could still us a gauge since it has two outputs and the higher voltage goes to the gauge and one to ms.
any know where i can get the gauge the bmw people are using?
Old 3-17-09, 20:15   #11 (permalink)
  Total: 715 Power: 5
Well it got here today. I was very impressed with the quality. It even include a bundle of software 1. For mapping and another one that does full gauge replacement.
Ill add some detailed pictures.
Question and I heard that Jordan said this was possible but
1. Can MS work via serial to USB connection?
2. If yes then can the Wideband also work via a serial to USB connection?
At this point my car computer likely wouldn't be able to get two serial ports in it.
Old 3-17-09, 22:15   #12 (permalink)
  Total: 448 Power: 5
1. Yes MS works seriel to USB connection, That is how I do it.
2. Yes also works serial to USB with wideband, I do that also. I did lose the wire that came with the LC-1 though to connect to a PC.
I should point out that I have been unable to get a decent wideband reading on my gauge since the day I bought it . Due to my lack of ability and the fact that I gave up. I just bought a gauge (an innovate one) and im going to wire it directly to that, I could never figure out how to get the LC-1 to give Megatune a decent signal, it is either my dumb [fizzle] settings or ground signal noise. Umm yer, install it 100% better then I did when you do it. I found I couldnt understand the instructions, same lug but different bolt but same bolt etc. Too confusing . Ramble over.
174kw at 9psi KLDE-T
Old 3-18-09, 18:32   #13 (permalink)
  Total: 715 Power: 5
Does anyone know where I could purchase the style of gauge they used on the M3 in those YouTube videos?
Old 3-26-09, 1:23   #14 (permalink)
Radioshack ... it's an LED display panel. Doesn't include any circuitry, though ... that'll be up to you.
Looks like they just used a blank console switch, cut a hole, and mounted it to the back.
1994 Ford Probe 2.0L MTX
Kitted. Lambos. Slammed. 18s. T3/04E. LSD. MSII. Zoom-Zoom-Psst.
1996 Mazda 626 2.0L MTX
Lowered. 18s. P5 FSDE. MP3 PCM.
http://www.cardomain.com/ride/579518
Metallargy is offline   Reply With Quote
Old 3-30-09, 21:46   #15 (permalink)
  Total: 715 Power: 5
What type of circuit would it need?
