So if you dont know I gave Radar's MegaSquirt a good home and I still have lots to learn. I also have not opened the replacement wiring harness yet.
I guess I could PM him but I wanted to save being annoying for when I have more pertinent questions.
I have a few questions about my goodies.
1. Id have to check but I swear he said the Crank Pulley had been modified and that is why he was including it with the MS setup. So my question is how is it suppose to look? This is identical to all the stock pulleys I have.
2. Okay so plug wires for the coil pack. He sent NKG's which look stock since I have a match pair here. My question is, it appears that he just took the stock ends (plastic) off and slipped the metal ends inside. So could I do this to my plug wires that match my car?
3. What do I need to close off the hole left over from removing the disty?
4. There is a pack of wires and a smaller black box that is hanging from the MS Unit. Out of there come another set of wires and the connection on it looks like that kind you use to hook up trailer lights. What this?
5. I assume the sensor I receive is a coolant sensor. Given that is looks almost like the stock unit except the tip is open plastic mesh with a blue thing hanging down, it looks like a small round LED. Why is this needed with the MS unit? Is this a turbo only thing?
6. Is this statement correct? Since I have his wiring harness for the MS and I purchased wideband, I can when I install this all correctly
that I can completely remove the stock ECU and harness.
