Go Back   Mazda MX6 Forums: MX6 Forum > Open Forums > General Automotive > Engine Management > 2G MX6 Engine Electronics and Management
Old 6-22-09, 21:39   #1 (permalink)
  Total: 10 Power: 0
KLDE ECU info needed ... Help
Hi MX6ers ...
i recently bought a used MX6 KL engine without the ECU ... the intake has the short neck so i suppose that its the KLDE ... what would be the correct ECU to get, to ensure it runs properly ??
This is to go into my '97 Mazda 626, so it should bolt up easily, and the old transmission should work fine ... should it ???
the main thing is, that i want to get it started and need to know what ECU i need to get ... i see so many different kinds selling out there (especially for the KLZE) , and dont wanna get the wrong one ... HELLLLLP ... Thanks
juniorgr is offline   Reply With Quote
Old 6-22-09, 21:44   #2 (permalink)
  Total: 203 Power: 5
probinator's Avatar
you will need a obdII ecu, I dont know the numbers off hand but obdII if you car is a 97.
89 Ford Probe GT, It's not stock.....
chip info here.http://www.cardomain.com/ride/728690/1
ZE Eprom Chips, and First Gen GT chips for sale.
probinator is offline   Reply With Quote
