Go Back   Mazda MX6 Forums: MX6 Forum > 2G MX6 (93-97) > 2G MX6 General > 2G MX6 Forced Induction
Old 2-21-07, 0:21   #1 (permalink)
  Total: -50 Power: 0
2.5 V6 TURBO setup almost done!!!!!
Today I got the car going with just an AFPR no FMU since I'm still waiting for the order, I couldn't hold my desire to drive the car in ^_^ I i went and tested the car, got boosted to 5psi in 2nd gear @ about 4,000RPM ebay t04e turbo 57trim.
Did that 3 times fairly quickly and stopped to cool off in between so I don't LEAN out for too long.
After the 3rd run a weird sound came from (the exhaust I think) only if itz above 2000,rpm or after I let off the gas, itz like a poping sound.......
What could it be? I super glued my EGR hole on the rear headerz so if that melted and startz leaking would that make a poping sound when i let my foost off the gas?
and I poped the hood to check how thingz are and found the hood to be extremely hot, especially the metal parts on my air filter(no intercooler)(my turbo isn't rapped up but I wrapped up the turbo collector pipes & downpipe that are under the hood... will I be okay?
I'm on max 5psi stock everything(even the fuel pump) 95-98Octane. spark gap 0.03"
The car felt great- itz now much smoother and powerful while in low RPM range than it was.
100% ebay partz 38mm wastegate, apexi style twin chamber BOV, 57trim t3/t04e turbo, ebay turbo manifold(downpipe hung too low so i had to cut bend & weld it)
The Ebay turbo I'd have to say it was great the seal did not melt & I have 1/8" oil inlet & 3/8 oil outlet no restrictors what so ever, 5w-40 Penzoil full synthetic oil designed for turbocharged & supercharged enginez.
just some pix
copex is offline   Reply With Quote
Old 2-21-07, 0:23   #2 (permalink)
  Total: 182 Power: 5
wheres the pics? and how easy was the ebay kit to install?
hers: 93 ZE. pretty much the same mods. + F&R drilled rotors, STS, h&r's
josey_gt is online now   Reply With Quote
Old 2-21-07, 0:30   #3 (permalink)
  Total: -50 Power: 0
Pix
Old 2-21-07, 0:38   #4 (permalink)
  Total: -50 Power: 0
large pix
Sorry I'm new the pix are too big should've posted linkz instead
well I didn't even need to get new slim fanz I just cut a little bit off the heat shielf from the back of the fan and turned my coolant reservoir the other way so the turbo could fit with minimum effort .
the whole thing is fairly easy I'd say if u got a Head with some brain, Stainless Mig welder, Grinder & all sortz of toolz ^_^ no big deal if you run max 5-6psi.
I might have a VIDEO UP ON YOUTUBE withing 2 weeks (after I install my 12:1 FMU) then I'll post the link on the FORUM.
Old 2-21-07, 2:08   #5 (permalink)
  Total: 1727 Power: 5
KING6's Avatar
sometimes i just laugh at how people do things.. lol..
Whats with the vacuum block? I had to block off vacum ports on the IM cause i had to many.
And more importantly.. Boost gauge in the engine bay?
Old 2-21-07, 12:25   #6 (permalink)
  Total: 221 Power: 5
he said it wasnt done yet and he just wanted to get an feel of it. he did a short cut just to have the car run if he able to get the turbo on the car im pretty sure he knows that the boost guage doesnt stay in the engine bay i hope he knows that. good job man and dont driving it again like that !! its takes a few seconds to melt somthing so take it easy you made it this far and good look i wanna see a video too.
93 black pgt 5spd (sold) 93 mazda mx6 ls (being rebuilt) 05 scion tc (hers) 93 mazda rs mx6 (donated) 05 toyota corrola le (traded) 96 mitsu eclipes (sold) 89 plymouth sundance (abandon)
84 honda accord should (have burned it, abandon) (DD car 94 mx3 rs 5spd interesting car it is.)
mazdaspeedX6 is offline   Reply With Quote
Old 2-21-07, 14:03   #7 (permalink)
  Total: -50 Power: 0
lol well I was on ebay browsing and I couldn't help it and umm yer the boost gauge I didn't know most setupz cant BOOST without LOAD now i have it routed outside my windshild + sticky tape..... couldn't find a way to get my vacuum hose to the cabin......
Old 2-21-07, 14:09   #8 (permalink)
  Total: 10 Power: 0
There's a gromit above the pedals, and you should be able to slide it though there.
sleeper6xxx is offline   Reply With Quote
Old 2-21-07, 15:22   #9 (permalink)
  Total: 986 Power: 5
i guess if you can laugh at other people that makes you feel better about yourself
94 MX3: 400+ whp E85 alcoholic. 13.0 @ 114 RIP
01 Yamaha YZ250
98 Ford Ranger 2wd- 5.0L twin turbo
Old 2-21-07, 16:46   #10 (permalink)
  Total: 607 Power: 5
did you peice it together from ebay parts or did you buy that kit for the probe/mx6?
The original "Mr. Clean"
Originally Posted by Goatcrapp
i'll ban the everliving [shizzle] out of you!
Please read this as many times as you need to, to digest the information.
JoKeR6 is offline   Reply With Quote
Old 2-21-07, 18:03   #11 (permalink)
  Total: -50 Power: 0
well
umm I bought all parts seperately picking the best & cheapest managed to pull the whole thing together under $1600 USD that was like 3 months ago tho.
Then I saw the whole kit for sale It's exactly what I pieced together, EXCEPT mine isn't intercooled...... I'm planning to get my Hood VENTED just enough to let out some hot air.
with the turbo I think the Ebay turboz now dayz are fairly balanced compared to years ago, mine seemed fine no probz.
Old 2-21-07, 18:13   #12 (permalink)
  Total: 88 Power: 5
Check and make sure its not a glued-together chinese copy that have become so prevalent on ebay.
Originally Posted by defiler View Post
TL;DR.
In other words, STFU and GTFO troll.
03 Police Interceptor Crown Vic
72 Mustang coupe
Karaha is offline   Reply With Quote
Old 2-21-07, 18:20   #13 (permalink)
  Total: -50 Power: 0
lol chill out why spend $240+ on a simple BOV? MY CHEAP $30 APEXI STLYE COPY WORKS GREAT LOL, first I put a vacuum tube on and give the diaframe a little push it opens....... fear it'll boost creep? just tighten the bolt on the top this car is old (1992 the first 2G batch) so everything I've done is pretty much half assed and cheap WHY>?? coz i only want the car to hold out for 3 more years of daily driving.
Old 2-22-07, 18:26   #14 (permalink)
  Total: 221 Power: 5
yeah but atleast do it up right man dont half ass stuff you aready spent 1600 on turbo parts that i know you want to use so do it right and you can have a more peaceful time driving the car an hear that bov let out. if not i'll be looking for your post in the forsale section saying (tubo kit for sell used with 10 miles on it.
Old 2-22-07, 18:45   #15 (permalink)
  Total: 5005 Power: 6
Goatcrapp's Avatar
do yourself the favor and stop driving it without any sort of fuel control.
5 psi, from a full t4 turbo, without any increase in fuel? thats a stupid move man.
What was your afpr set to? describe the popping more.
