Wondering about megasquirt maps
Hey, i was wondering if anyone knows where i can get megasquirt maps to get my car running. I have a lot of turbo stuff and want to put it all together with a megasquirt. I just need the maps to get everything started so it can be fine tuned later. And also what is the typical way of metering air with the megasquirt setup, do you convert from mass air flow to mass air pressure?
Any help would be appreciated. Thanks |
#3 (permalink) | |
The Full Dong
As for maps... Untitled Document |
#4 (permalink) |
Wow, thanks. That's an awesome link. Radar, i read an old post of yours saying that you could custom build a megasquirt ranging from 300 to 700 dollars depending on what is wanted, Do you still do this? And i take it that's your MX6 making 327whp in your signiture space, is that on stock internals?
#5 (permalink) |
Megasquirt Bulk Buy #5 - ProbeTalk.com Forums
Mate get in on that now asap. I did, best thing ever. Im pretty sure Radar/shaodome said this is his last bulk buy, so get in while you can. Best couple of hundred bucks you will ever spend. Lay off the hookers, get on the megasquirt bulk buy. |
174kw at 9psi KLDE-T
#6 (permalink) |
The Full Dong
Unfortunately...this will be the last bulk buy for any foreseeable future....
#7 (permalink) |
Hey Radar...I have a 2000 mazda 626 v6 with the KlG4. I have a Distributor less ignition, i am sure you are familiar with the set up..didn't you do a klze swap for kritter a while back? Anyways, what kind of a megasquirt set up would i need for my car? I would be interested in participating in the bulk buy if you could tell me everything i would need. I think everything is pretty much the same as a probe or mx-6. I don't want to buy a wiring harness for the probe if it won't work on my 626. What do you think?
#8 (permalink) | |
#10 (permalink) | |
Look at this way, Basic off the shelf standalone, at least $1000 for unit, $500 for installation, $500 for setting up constants. That is bare minumum, go look at that thread for prices on a Megasquirt. |
#12 (permalink) | |
Cf_z get any money you have, get in on the probetalk bulk buy. Then you can hastle Radar with your questions later like what I do(did). ![]() |
#14 (permalink) | |
The Full Dong
The downside is none of them will work without modification (unless you go fuel only) and don't come with any of the fun mods, like launch control, prog. outputs, wiring diagrams, install instructions, etc. |
#15 (permalink) |
[/quote]How can i get in on the bulk buy, and where can i find it on probetalk, i am super interested and would like a pre-programmed unit from Radar. Just tell me when, where and how much and i'm in. |
