#2 (permalink) |
Yer you should be fine. Ill let someone with a supercharger fill you in 100%, but 5psi is enough on the stock injectors. Might want to bump up base fuel pressure a bit though with an adjustable fuel pressure regulator. If you got milleniaS/Eunos800s injectors you wouldnt need to bump pressure.
#5 (permalink) | |
. Lucky I had a spare manifold because I couldnt get 2.If you want to supercharge, you might as well get the injectors. A couple of hundred bucks for the knowledge that it will work 100%. You dont have to tune anything, maybe lower base pressure a bit for it to idle better. you should have an adjustable FPR for a boost application anyway. No modifications, they fit right in to stock rail and use the stock plugs. |
#8 (permalink) |
MilleniaS. Millenia 2.5's im guessing will be the same as ours. The MilleniaS injectors (from the 2.3: supercharged engine) have a flow of 270cc(from memory) and our ones have a 220cc flow.
#12 (permalink) |
yea the milleniaS is a rare car, and there are fewer ones of those around than a 97 LS. You can go check Probetalk and the for sale forums there, i remember seeing a pair on sale by some guy over east.
RIPLooking for a 2nd gen Mx6 (v6 & MTX) [/color] |
#14 (permalink) |
come out of the sr20DE-T, and i belive there actually 370cc? i picked a set up already fitted into KL rails about 4 months ago for about 175US or somesuch
1993 626 Hatch, ??? @ ??? mph
Klze, its got a few things done to it ![]() Really need to update that -> http://www.cardomain.com/ride/2330972 |
#15 (permalink) |
Personally I hate injectors being reffered to by colour. What car they came out of, and what they flow is easiest referance.
You cant run Nissan injectors without a standalone ECU. Seeing as you want to use a FMU, you have to stick to MilleniaS injectors. I saw them on ebay everynow and then. buy a set, have them cleaned and flow tested. |
