help me justify megasquirt!
So i kinda realized that megasquirt is about the last thing ive got to have a full (/good?) turbocharged setup. Ive realized that im getting like 13 mpg in the city (and thats even with decent driving), more than likely because im at 10:1 fuel ratios in boost.
But, as i am going off to college in 2 months, i need all the money i can save. I originally thought i was gonna sell this car and buy something a little more 'normal', but i soon realized that i cant take that kind of loss. im just gonna drive it till it blows up .I know nothing about megasquirt other than its another computer that handles the fuel. a few questions: Does anyone have their fmu VS megasquirt gas mileages? (or estimate?) If i cannot (ever) get the megasquirt tuned, would i still be better off using the basemap that it is sent to me on than my current fmu? I dont have a laptop. do i need one? really, How hard is it to install? and is there any possiblities that it can mess something else up? Should i just get a 6:1 (or so?) recalibration unit for my fmu? |
#2 (permalink) |
Get a Megasquirt, Or Ill Kick you in the nuts.
, you need a laptop.. I just got a cheap one off ebay for like $200 shipped, its worked great. It doesnt require much on the computer, Though a long lasting battery is good to have.Its not that hard, any you will have lots more control with just a simple unit. There are enough basemaps out there to get you started as well. |
#3 (permalink) |
Gas mileage will be from what ive seen, much better. Better as in you will pay off the MS just on the gas mileage thing in a few months for sure. Driving on bigger injectors with just lower fuel pressure still means you are drinking through more fuel then you should even when you are not on boost.
Ask King about the basemap and FMU. I would say so from videos ive seen. power is more linear, and definately safer. Your running stock timing, I would say that the reason the MS basemaps might not go as hard with an FMU is because the timing is quite retarded to be on the safe side. I drive around on my basemap pretty much, only touched it up a bit on my own. Also at the end of the day, you can wait a few months and then save up another couple of hundred and get someone else to tune it for you on the dyno. It is so piss easy to install. Instructions all there, colour coded and wiring diagrams. took me 2 hours(really taking my time), If I had to do it again, 30 mins I could push it over I reckon. No. ![]() |
174kw at 9psi KLDE-T
#4 (permalink) |
-No more MAF sensor if you decide to go with velocity air instead. This will free up some restriction in your setup. -A good shop will be able to maximize power/efficiency from your motor. A base map is a great starting point. Every car is different, so it's a good idea to take some time to "fix" the base maps to suit your motor. You will be able to save gas with a decent tune too. |
#5 (permalink) |
The good thing about MS, is that you can have 2 tunes. 1 for gas mileage going to school and back / around town, and 2 for your boosting needs.
This would allow you to drive around safely and maximize gas mileage when you need to yet get the max performance over a FMU. Although you could take the best of both worlds and try to make 1 tune, and just take it easy on the lead foot. _Edit_ Nevermind the 2 tunes. Its basically 1 tune without boosting to save Gas mileage. < speaks jibberish |
#6 (permalink) |
Here's something ive been thinking about for a while..
is it possible to change settings to decrease the cars driveabilty..maybe over boost protection? Example: I want to bring my car into get an alignment, But I dont want some loser at the tire shop taking my car out for a test drive. Because it happend before. |
#10 (permalink) | |
The Full Dong
#11 (permalink) |
to help you justify buying megasquirt as far as the install goes. I just got mine from radar on Friday and on saturday it took 15 mins to tap and cut all the wires needed and about 30mins to wire the harness the rest of my time was spent makeing it look good. i havent gotten a chance to play with the tuneing yet but if your worried about it being hard to install dont be scared
