Defective VRIS..no time to replace before road trip - Mazda MX6 Forums: MX6 Forum
Old 7-22-04, 16:47   #1 (permalink)
Murphy's Law.
so...What would be the ill effects of driving with a faulty VRIS silenoid?
I"m almost 99.6% sure it's the #1 Vris, as it idles fine and accelerates to 3100rpm fine, than sorta of gets grumpy and stumbles after 3250 all the way to 4250.
Would this damage anything?
I would of replaced it today, however couldn't get the part in time, and I'm headed for a 16hour trip tomorrow
opinions?
Thanks
Eviltwin is offline   Reply With Quote
Old 7-22-04, 18:20   #2 (permalink)
no one?
basically I can do highway travel at 105kph (60mph) or 140kph.
As long as I'm over the 4250 range it's smoother.
bad idea? bad gas mileage? bad for the engine?
gotsta know!
Old 7-22-04, 18:23   #3 (permalink)
  Total: 23 Power: 5
its not bad for the engine u might get a lil worst gas mileage thats it you can also zip-tie the vris butterfly open its better then not workin at all
sik6 is offline   Reply With Quote
Old 7-23-04, 17:28   #4 (permalink)
  Total: 355 Power: 5
Define "stumbles"... VRIS defects don't usually cause the engine to stumble (in the traditional sense: a rumbling or erratic behavior). In other words, if you are feeling a true "stumble" then it's likely something else.
If you mean "stumble" as in "loses it's breath" or something, then yes this can be attributed to failing VRIS - the zip-tie method works fine to help out a bit there.
Visit http://schwinn.hopto.org/ for common MX6/Probe Procedures and other useful docs/links (Downloads fixed 3/24/07)
Proud member of the NMA: Defend your right to drive at http://www.motorists.org/
schwinn is offline   Reply With Quote
Old 7-23-04, 17:35   #5 (permalink)
Shwinn you're absolutly right-
it's actually my dist.
check this http://www.mx6.com/forums/showthread.php?t=102367 (*Distributor problems....NOT VRIS. Please read*)
