my clutch is gone? - Mazda MX6 Forums: MX6 Forum
Old 8-4-04, 0:49   #1 (permalink)
  Total: 13 Power: 5
my clutch is gone?
I have a new clutch since 8-9 month.. I made it replaced when I bought the car.
Today it started slipping very badly. in every gear.. even if i'm like in third gear at 2500rpm, if I step on the gaz it slowly move and the rpm bang to like 5000 very fast. it does that in every gear..
Anyone know if it can be caused by a lack of fluid or something like that?
Because I rarely abused that clutch.... !!
JeanFran is offline   Reply With Quote
Old 8-4-04, 1:00   #2 (permalink)
  Total: 38 Power: 5
wut clutch is it and how many miles you have on it, did you break it in
Nick51 is offline   Reply With Quote
Old 8-4-04, 1:06   #3 (permalink)
  Total: 13 Power: 5
It's the OEM clutch.. I have 10 000 miles on IT.. and I didn't do any breakage stuff.. the mechanics guy tells me it wasn't necessary
Old 8-4-04, 2:12   #4 (permalink)
  Total: 38 Power: 5
that might of been your problem, not breakin in the clutch and it probably didnt seet right against the flywheel. Did you get your flywheel resurfaced?(somebody correct me if im worng) i just got a spec stage 1 and had to break it into like 550miles
Old 8-4-04, 3:14   #5 (permalink)
  Total: 110 Power: 5
Yes, you must resurface the flywheel and break in the clutch at about 500 miles.
2008 Honda Fit
Larry is offline   Reply With Quote
Old 8-4-04, 8:37   #6 (permalink)
  Total: 13 Power: 5
Yes, the flyweel was resurfaced, so that's not the problem..
Old 8-4-04, 9:24   #7 (permalink)
  Total: 950 Power: 5
Transmission fluid has nothing to do with the holding capability of the clutch.
Unfortunately, diagnosing and/or correcting the problem is going to require removal of the transmission (aka alot of labour).
There's a lot of times where it seems he tries to sound smart by stringing together a bunch of words, but it just ends up making no sense and he ends up looking like a [fizzle]face.
Malicious is offline   Reply With Quote
Old 8-4-04, 10:27   #8 (permalink)
  Total: 13 Power: 5
This is a pretty radical solution to remove the transmission.. i'M gonna ask my garage if there is anything under warranty.. I called them and they tell me to check the clutch fluid but it's fine. I need to recall them at 7PM to speak with the good person :|
Old 8-4-04, 10:47   #9 (permalink)
  Total: 950 Power: 5
I would be looking for a new garage if they told you to check the clutch fluid
And no, it's not a radical solution. If you want to inspect the clutch or its components for damage, the transmission has to come off. Simple as that.
Don't forget to check your blinker fluid and muffler bearings!
Old 8-4-04, 10:56   #10 (permalink)
  Total: 13 Power: 5
LOL
the mechanics also told me it may be the cylinder ...
Old 8-4-04, 10:58   #11 (permalink)
  Total: 950 Power: 5
Yes, it probably is assuming the clutch was installed and broken in properly.
The slave cylinder may not be applying full pressure to the release fork if its broken.
Old 8-4-04, 16:23   #12 (permalink)
The Full Dong
  Total: 450 Power: 5
Radar's Avatar
umm...why is this in the F/I forum?
Turbo KL 400whp/407tq - SHAODOME @ PROBETALK
Successfully Megasquirted: 94 MX6-ZEt, 92 MX3 ZE, 94 MX6 LS, 96 PGT ZE, 96 PGT w/ every bolton, 93 PGT, 93 PGTZE, 95 PGT ZE, Celica GTS built 20v-turbo, 95 PGT, 97 PGT ZE, 97 MX6 KLZE, 97 PGT w/ botlons, Mazguy's Built MX-6 Turbo, 97 Mustang V6 EDIS, Delorean with a T70 Turbo, and a 87' Built 1.8t VW Golf (25psi),97 SE-T. No more sig space
Radar is offline   Reply With Quote
Old 8-9-04, 14:50   #13 (permalink)
  Total: 13 Power: 5
I know it's in the Wrong forum sorry I clicked the wrong link...
I have some bad news, the mechanics removed the transmission and they tell me the lining is out.. it's broken.. the clutch themsell isn't worn at all it's like new. They tell me I may have missed a gear, like going at 120km/h and put it in second .. WTF, i'venever done that. So they don't want to pay for the repair.... It's going to cost me 160 for the clutch and 260 time + 30 flyweel..
