The factory alarm is very simple.
Your best bet, is get a good after market alarm, that incorporates keyless entry, remote start, start disable, audible and visual confirmation. You will appreciate the more features an after market alarm offers.
As for wiring in the factory alarm, you would need to rig up a relay system, that would send a signal to the factory alarm telling it to arm and disarm. Disarming is done through the door locks, I think driver and trunk. Arming is through locking both doors from driver side, then closing door while holding up door handle.
If you install an aftermarket alarm, you can permanently disable the factory alarm by disconnecting the hood switch, located in the front hood latch assembly.
