engine wont start and makes squeaking sound - Mazda MX-6 Forum
post #1 of 6 (permalink) Old 7-25-05, 14:17 Thread Starter
well basically there is plenty wrong with it and i have no idea how to fix it. so the engine isn't getting fire but rotor isn't dirty cracked or anything.so i have no clue what the problem is. and also when im trying to start the car there is a squeaking sound and i have no idea where its coming from. come on man i really need to get this car running!
firstcaris_mx-6 is offline
post #2 of 6 (permalink) Old 7-25-05, 15:54
dsr30's Avatar
have u actually checked for spark? if there's none, then the usual ignitor bug might've struck. there's a thread in the projects section on how to install the hei mod to fix it.
If my reply is helpful please leave me some karma
http://www.cardomain.com/member_page...page_id=761672
Running a FASTEST95PGT built megasquirt, great service and support, Jeff's the man.
Illuminas, PGT 16" rims, hood pins, ZE cams, RR front mount insert, ATX-MTX, mx3 flywheel, XTD 6 puck clutch, MSD Blaster 2, Civic STS, Walbro 255lph, ph8A oil filter, Clutched Eaton M62, Nissan 370cc Injectors, MSnS-E, M3 Mirrors
dsr30 is offline
post #3 of 6 (permalink) Old 7-25-05, 18:08
first off, check for spark by getting a spare plug, pulling your spark plug wire out and plugging the spare plug in. make sure the plug is grounded with the block then try to start the car up. if you dont see any spark, chances are you need a new distributor. Also, your squeaking is probably one of your accessory belts. if you want to make sure, just have a buddy listen for that area while you try to start the car
Last night I dreamed I was a muffler... needless to say I woke up exhausted.
AAlonzo is offline
post #4 of 6 (permalink) Old 7-25-05, 21:58
The squeking is from the Alternator belt u will have to tighten it.
MadBad is offline
post #5 of 6 (permalink) Old 7-25-05, 22:26 Thread Starter
well the wierd thing about the squeking is that it didn't start happening until after my uncle (master mechanic in his own mind put water into the coolant filler cap.so im thinking that it has something to do with that.
post #6 of 6 (permalink) Old 7-27-05, 7:15
probably just spilled some down onto the belts. If so the squeek should go away. I usually spill a bit when I fill my cooling system 50/50 mix of course and it will squeek for a little while.
93 LS Mystere V6, MTX, Stage 1 Clutch, Shiny Gold paint job, 194500km, nice rims,
RustyRed6 is offline
