Old 5-14-06, 12:17   #1 (permalink)
  Total: 933 Power: 5
kid_puma's Avatar
4WS question ?
What's it like to drive a 2nd gen MX-6 with 4WS?
Can anybody tell me what the advantages of 4WS would be ?
I mean its not like you see it around everyday. Also i hear that their are lots of problems with it .
Click here to see Video
1 Does anyone have a 4WS Mx6 on a skid pad or doing a skid/drift whatever ?
2 Is this an advantage over domestic 2WDS mx6's
3 lol are you going to be able to steer better cause of it ?
4 Is it all that it's cracked up to be?
5 4WS vs 4WS switched off ?
6 What happens @ a high speed turn/ corner ?
Any good input will not go unnoticed
kp-
Old 5-14-06, 21:36   #2 (permalink)
  Total: 38 Power: 5
My MX6 has 4ws, i think that it is great. Basically it feels like the 4ws gives you a much smaller turning circle so when you turn the steering wheel it is as if your steering wheel movement is amplified. I have not had any problems with the 4ws mechanically but I have heard that it is pretty expensive to have fixed.
I find that the 4ws is good for doing handbrake turns because if you sit in the back of my car when going around a corner normally, it feels like the back is sliding out. That is because the rear is getting steered around the corner instead of being pulled around the corner. It feels like when I go around a corner the rear end of the car (because it is steering around the corner) has enough momentum to start a slide without having to do a turn in the opposite direction first to build momentum to swing the back out. But when you straighten up it sort of flicks back because of the 4ws.
Some would say no but I say that it is advantageous over 2ws, 4ws is great for u-turns and parallel parking. When i drove a 2ws mx6 it almost feelt like it was understeering.
Of course, especially at low speeds it is more noticable.
If I had the choice between 2 MX6s for the same price. one with 4ws and one without 4ws I would go for the one with 4ws, however if the one with 4ws was an extra 500 then I would go for the one without 4ws. Its good but its nothing to get all excited about.
I dont think you can turn off the 4ws if the car comes stock with 4ws.
As you go faster the angle that the back wheels turn gets smaller. So when you are parking or going really slow the rear wheels turn as far as they go (like in the above pictures) but at 50mph you almost cant feel the effects of the 4ws because the rar wheels do not turn a much.
...A journey of a thousand miles begins with a single step...
1992 Mazda MX6 Custom Blitz Front Bar, CWest Skirts and an Apexi Rear Lip Moulded onto a lowered rear bar, ADC carbon fibre mirrors, 17" Blaze Wheels Powdercoated white, Custom White/Red Interior, recaro racing seats, momo shifter and pedals, In-Car Mood Lighting, Checkered Plate Flooring, Custom Sub Enclosure, Underbody Lighting Kit, KLZE, Blitz Grounding Kit, Simota COld Air Intake, Tanabe Full Exhaust System, Removed Cat.
Lyall_s is offline   Reply With Quote
Old 5-14-06, 22:35   #3 (permalink)
  Total: 479 Power: 5
yes, it makes it much more easy to manoeuvre at lower speeds, and also is great in carparking. my driveway is a PITA to reverse down, and so having the back end of the car also steer is a real bonus
91turbo666 is offline   Reply With Quote
Old 5-15-06, 21:09   #4 (permalink)
  Total: 933 Power: 5
kid_puma's Avatar
just like to thank you guys for the wonderful replies,
kp
Old 6-19-06, 7:52   #5 (permalink)
  Total: 24 Power: 5
roflcopter ok 4ws is teh best in my opinion, i would neva go without it, i have driven my car with it disengaged (fault) and it DID understeer... a LOT... to the point where the front would skid then the back would skid then vice versa again and again then with it back on it seemed to flow around the corners... as if the back of the car was moving out to catch the body rolling... its amazing... and at 57kph the 4ws changed direction... say at low speeds its opposite lock and at high speeds it chaniges direction so the roar wheels face the same way as the front ones... like crab crawling and i would pay an extra 500 - 1000 for a 4ws mx6... i wouldnt be without it the mx's key feature is the 4ws, why be without it? it was designed to have it; enjoy it!
Mx6 race project.
D347H is offline   Reply With Quote
Old 6-19-06, 8:29   #6 (permalink)
  Total: 629 Power: 0
Asuna's Avatar
I dont have it but thanks for a really good laughtLMFAO!
That little car is so sick man!
Asuna is offline   Reply With Quote
Old 6-19-06, 8:36   #7 (permalink)
  Total: 479 Power: 5
D347H is right, the 4WS is another feature that really makes the mx6 stick out as something unique here.
i took the car for a spin on gravel yesterday, from what i can tell the 4ws helps get rid of some of the body roll in slides around corners.
its hard to explain....have to try it for yourself!
Old 6-19-06, 12:21   #8 (permalink)
  Total: 150 Power: 5
Originally Posted by kid_puma
THATS MAH CAR!!!! Yes 4WS is the [shizzle]... the best invention ever. Ive lost the 4WS and it feels like crap without it. I DD a 4WS car and weekend drive a E-Spec (2WS) and there is a major difference... i cant even explain how good it feels...
-justin
-Justin-
1995 Pontiac Trans Am WS6 Clone
-Boosted-
*Still Trollin' around
oredroc4 is offline   Reply With Quote
Old 6-19-06, 14:54   #9 (permalink)
  Total: 120 Power: 5
Does anyone have any under car shots (when the car is on a lift) of the 4ws setup?
Dan
Life, Liberty and the Pursuit...
93 MX6 LS part out
95 K2500 - i/c/e 4L80, 93 formula LT1 4L60 95 S10 v8 swap, ~400hp Vortec SBC, 4L60, fuel injected, 3.23 spool
drumer919 is offline   Reply With Quote
Old 6-28-06, 6:21   #10 (permalink)
  Total: 59 Power: 5
I was about to request the same thing, I really want to see that too
RickyRick is offline   Reply With Quote
Old 6-28-06, 7:15   #11 (permalink)
RdS
  Total: 513 Power: 5
^^[fizzle], i always wanted to take pics of my setup, as the underside of my car was immac... but never did
i think i might have a shot with it in it.. ill look.
anyway, in the meantime enjoy the retartedness:
things to remember:
-goes opposite way UNDER 55kmh
-goes same direction as fronts above 55kmh
-automatically tries to straighten up when the ignition is turned off (so it doesnt look so spaz when parked )
- and if it ever breaks, it locks straight.. so you never loose
it was a main gimmick and one of the reasons that made me look into the mx6 in the first place
Red GE's FTW. GE20L200102537 ?? :'(
RdS is offline   Reply With Quote
Old 6-28-06, 8:30   #12 (permalink)
  Total: 629 Power: 0
Asuna's Avatar
OK SOMEONE HAS TO: make a kit or sometrhing start getting parts over here! id swap it in my car!!!!!
Old 6-28-06, 9:30   #13 (permalink)
  Total: 265 Power: 5
I remember reading that 4ws is not a advantageous as you would think when it comes to performance. Like someone said....its a gimmick. Why dont you think more sports cars come with it?
ozmojo1 is offline   Reply With Quote
Old 6-28-06, 13:53   #14 (permalink)
  Total: 403 Power: 5
It helps for parking, not as much for handling.
94'LS KLZE,S-AFC,MSD6AL,SS-Headers,2.5" CB,CM Stage3,MX3 FW,CAI,Probinator chip,Konig 15",RRMounts, Illuminas, Sprint Springs, Brembo Slotts Rotors, Hawk Pads.
Old 6-28-06, 21:20   #15 (permalink)
RdS
  Total: 513 Power: 5
well i know nissans version 'HICAS' in the R33 skylines makes it worse at high speed conrnering, makes the ass end uneasy. in the mx6 it was fine though.
and it was a gimmick, just like turbo's in the 80's, 4WS in the early 90's was HAWT! but it only made a real impact on FWD cars, like the mx6, where it really got rid of the understeer, and made the handling better.
a GD mx6 turbo without 4ws is a joke. they handle like a turd, and once that turbo kicks in? well, it corners like it is on skis.... straight!
