Car Will Not Idle - Mazda MX6 Forums: MX6 Forum
Old 5-12-07, 9:40   #1 (permalink)
Car Will Not Idle
I mentioned in another thread that my water pump went bad and the car overheated. Had to change the water pump then realized that there was water in the cylinders and replaced the head gasket. Before taking everything apart I put a mark on the distibutor to indicate it position. Now that everything is back together to get the car to start had to rotate the distributor all the way counter clockwise. I have checked the timing with a timing light and it is correct. It starts now, but will not idle. At 1000 RPM and higher it seems to be ok.
Any ideas???
Hirschey is offline   Reply With Quote
Old 5-12-07, 10:37   #2 (permalink)
  Total: 356 Power: 5
SAdrmmr04's Avatar
did you check for engine codes?
"Jesuscristo, es un león. Méntase el auto!"
>:3
back again to bring life to the lounge
SAdrmmr04 is offline   Reply With Quote
Old 5-12-07, 12:39   #3 (permalink)
no autozone or o'reillys can read an obd 1... how do i read them meself?
Old 5-12-07, 13:46   #4 (permalink)
  Total: 356 Power: 5
SAdrmmr04's Avatar
1993-1995 Engine Controller Malfunction Codes
at the top it shows a list of common codes. just take a wire and jump the TEN and GND terminals on the diagnostic box in the engine bay. then turn your car to acc (but not on) the light will flash slow then fast. the slow is for the fist number and the fast is for the second. it explains it on that page
>:3
Old 5-12-07, 14:00   #5 (permalink)
I looked at that connector. There are metal connectors inside some of the holes, but there is not one in the TEN spot.
Old 5-12-07, 14:35   #6 (permalink)
heres the pics of mine...
Old 5-12-07, 15:24   #7 (permalink)
  Total: 356 Power: 5
SAdrmmr04's Avatar
well thats some [shizzle]....i dont know how to test it then
unless you can track where the wire goes into that slot and touches the metal clip then jump it from there?
>:3
Old 5-12-07, 16:22   #8 (permalink)
  Total: 19 Power: 5
sounds to me like ur 1 tooth out on the timing belt
92 Ford Telstar V6 KL-ZE: CAI, 17" Chromies, Sprayed Painted Interior, F & R Seat Covers, Lowered, Front Strut Brace, Manual Conversion! 2 Sony 15" Subs, Alpine 5x7's in da front, Alpine head deck, Response 2 x 380WRMS amp, HEI Mod with Blaster 3, White Face Gauges, 55watt 6000k HID's
Tx5guy is offline   Reply With Quote
Old 5-12-07, 16:59   #9 (permalink)
Thats was my guess as well. I will check everything again tomorrow. With the engine in the car it is kinda hard to see everything. Where should the crankshaft key be, straight up or a bit counter clock wise?
