please help my car stalled and now will not start - Mazda MX6 Forums: MX6 Forum
Old 6-17-07, 11:14   #1 (permalink)
  Total: 96 Power: 5
i hate to start a new thread but i have not really been finding the info i am looking for. but if anyone could help i would appreciate a lot. i need to get it running hopely for work asap Thank you
my car is a 93 mx6 ls 5 speed
i was driving through a parking lot and my car just stalls out and will not start after that. i am not getting any spark but i can not tell if got a short or what starter sounds fine and turns over just fine
thanks ryan
Voller is offline   Reply With Quote
Old 6-17-07, 11:32   #2 (permalink)
  Total: 161 Power: 5
The ignitor module inside the 93-94 distributors are very prone to failure, fortunately, this can be repaired quickly and inexpensively with a HEI module.
The following links have contain great info in the HEI MOD>
http://www.mx6.com/forums/2g-faq-per...l-install.html (Project: HEI Module & External Coil Install)
ProjectMazda :: HEI Ignition Module install
Also, here is a diagram for the HEI wiring (on a 93-94)>
(Note, that no internal modifications need to be done to the disty when using the internal coil)
DrHalo is offline   Reply With Quote
Old 6-17-07, 11:48   #3 (permalink)
  Total: 96 Power: 5
i was wondering it the hei mod would work will diffenltly look in to that
Old 6-17-07, 11:51   #4 (permalink)
  Total: 161 Power: 5
Have you checked for Malfunction codes?
Here is the very usefull site> 1993-1995 Engine Controller Malfunction Codes
Old 6-17-07, 12:00   #5 (permalink)
  Total: 260 Power: 5
gehofff's Avatar
Also check the ENG INJ fuse in the fuse box under the hood.
Originally Posted by BrokenJohnny View Post
What's an FD??
gehofff is offline   Reply With Quote
Old 6-17-07, 15:02   #6 (permalink)
  Total: 96 Power: 5
looks like the coil is out of the range as in the way for resistance. so is that something that is a independent part for the distributer or is it all one part. And recommended place to get one
thanks Ryan
Old 6-17-07, 15:11   #7 (permalink)
  Total: 161 Power: 5
I suggest doing the HEI mod with the external coil. (it will cost a fraction of the price of a new disty)
If you dont want to modify a disty cap , PRD makes a modified cap for just such an application.
PRD Online
Old 6-17-07, 15:25   #8 (permalink)
  Total: 161 Power: 5
Apparently, the coil can be replaced, the following site contians the Mazda part numbers> Probe/626/MX6 FAQ - Problem Areas
Old 6-17-07, 16:16   #9 (permalink)
  Total: 16 Power: 0
Sounds like time for dizzy or HEI mod, Probetalk.com has a nice wiriteup on all the diff years and external and internal coil on their site as well. If u search here it should come right up. i have a 93 mx6 as well
psimx6 is offline   Reply With Quote
Old 6-17-07, 17:20   #10 (permalink)
  Total: 96 Power: 5
this is kinda a dumb question but do you have to use a the external coil or can the hei mod use the internal one like in my where it is not working and get my car running cause i been searching around and a few of the writes are talking about optional external coils hopefully that makes since
Old 6-17-07, 23:39   #11 (permalink)
  Total: 96 Power: 5
well tried the hei mod without the external coil and stil will not start do you think if i replaced the coil it would work or the ditsy or what
Old 6-18-07, 11:56   #12 (permalink)
  Total: 161 Power: 5
The following are mazda/ford Part numbers for the coil itself, as listed in the TSBs.
KLY1-18-V80 (Mazda)
F32Z-12029-AA (Ford)
I have no idea what they will charge for one of the above, as a new disty costs in excess off 300 bucks. (Alternatively, you can get a second-hand one from a wrecking yard)
If your coil is fried, replacing the coil will fix your problem. However, the HEI mod with external coil remains a good idea, as any future failures can be repaired quickly and swiftly.
Do you have any malfunction codes? (a similtainious failure of both the crank and cam sensors can cause a no-start in the 93-94)
Have you checked the EGI-INJ fuse as suggested by Gehofff?
