Old 10-18-07, 14:53   #1 (permalink)
  Total: 17 Power: 0
need help changing my starter
My engine wont start. the battery is fine and the people at advanced auto told me to bring in my starter. I think I know where it is but I am not sure. somebody please help me find it thanks.
nick is offline   Reply With Quote
Old 10-18-07, 19:47   #2 (permalink)
  Total: 735 Power: 5
Welcome to the board!
Is this a V6 or an I4? If it's a V6, look below the air filter box, for a cylinder-shaped thing, with one thick wire (from the + battery terminal) and one thin wire attached to it. I don't know exacty where it is on an I4, but if you follow the + battery lead, you will find it.
Old 10-19-07, 2:25   #3 (permalink)
  Total: 746 Power: 5
David's Avatar
It'd be the circled part. And it's just below the intake box.
David is offline   Reply With Quote
Old 10-19-07, 13:18   #4 (permalink)
  Total: 17 Power: 0
Thanks for the help. I have a 4 cylinder so I don't know if it is in that spot or not. That picture looks like a v6 but I will check there anyway. I will look for the battery wire too if it isn't there.
Old 10-19-07, 13:36   #5 (permalink)
  Total: 17 Power: 0
I checked and the wire does go to where you said. The problem is that the intake box is blocking it and I don't know how to take that thing out to get to it. I can try but I am afraid I'm going to screw it up.
Old 10-19-07, 13:39   #6 (permalink)
  Total: 746 Power: 5
David's Avatar
Just make sure you reattach everything. There's a phillips head screw on the end of the throttle body that attaches the black plastic elbow. It'd probably be easiest to remove that as well. Just unscrew it and it should slide off the end of the throttle body. There is 1 vacuum line attaching to the box, make sure you don't forget to reattach that as well a harness plug to the MAF. Other than that you're good to go
Old 10-19-07, 13:42   #7 (permalink)
  Total: 460 Power: 5
Blake's Avatar
Dont be afraid to dig in there, the air box will not be hard to get out. A starter is an easy job so dont get too worried about it.
Welcome to the boards by the way.
Red Mazda MX6 LS
King6:Ricers dont have weed, there to busy scouring ebay. (lol)
Blake is offline   Reply With Quote
Old 10-19-07, 14:21   #8 (permalink)
  Total: 17 Power: 0
Thanks guys. I am going to try and get that thing out now. Hopefully i don't mess it up too bad.
Old 10-19-07, 14:58   #9 (permalink)
  Total: 17 Power: 0
I got the intake out, and the starter was not there. I guess they put them in different spots on 4 cylinder. I can't see the battery line so unless someone knows where the starter is on the 4 cylinder I guess I have to take it to a mechanic. thanks for the help though.
Old 10-19-07, 15:05   #10 (permalink)
  Total: 746 Power: 5
David's Avatar
Don't take it to a mechanic. Give me a couple minutes, I'll find it for you. It looks like it's on the firewall side of the transaxle ie transmission. I'll post up a diagrahm in a sec, I just have to scan it in.
Old 10-19-07, 15:07   #11 (permalink)
  Total: 49 Power: 3
David if you cant find it I can write out the procedure from the haines manual. It covers I4 and V6
1996 MX-6 LS MTX (formally ATX) KLZE, Exedy Clutch, Magnaflow exhaust, 8.5mm MSD wires, CAI, Jspec Headlights and Tails, 17" sportmaxx rims
Consequence is offline   Reply With Quote
Old 10-19-07, 15:11   #12 (permalink)
  Total: 17 Power: 0
Thanks for looking. I looked everywhere in there and I couldn't find it. The battery line was impossible to follow.
Old 10-19-07, 15:13   #13 (permalink)
  Total: 49 Power: 3
Well I will give you a heads up. In the haines manual it asks you to remove your air intake duct and housing, judging from the pics I have, its probably under there somewhere, if david cant get you what you need I will write out the entire procedure step by step for ya.
Old 10-19-07, 15:19   #14 (permalink)
  Total: 17 Power: 0
Thanks. Where are the housing and the duct? Is the housing the box? and I guess the ducts would be the 3 tubes coming from it. I didn't see it down there.
Old 10-19-07, 15:22   #15 (permalink)
  Total: 746 Power: 5
David's Avatar
