#16 (permalink) |
dude that sounds exactly like mine
YouTube - ghey knok from my mx6 2 YouTube - ghey knok from my mx6 |
#18 (permalink) |
videogame - unless you replaced the tensioner yourself, you don't know what was done 5k ago by the previous owner.
I always (for instance) ask for old parts back from the mech right from the start when i drop the car off (on the rare occasions i take my DD in during us open season when i have no time to work on it myself), not because i want the old parts but so i know they were in fact replaced. Its a fairly easy test. remove the tensioner (if you have tiny hands and tiny stub tools, you can get it from up top,.. otherwise you'll have to take the passenger wheel off, remove the splash guard and access it from the side) and try and compress it by hand. if its easy... or doesn't extend on it's own.. that's (potentially) your problem. More often, on higher mileage 6's - its a combination of tensioner, collapsed hla, etc. I gotta tell you though - that sound from the video has a different timbre to me than regular old hla tick OR TBT tick... it's a lot more pronounced (judging by the relative volume of it to your voice) and sounds almost like something is hitting the bottom of the VC. If that isn't it - take the IM and rear VC off, and look at the cams - make sure they're not marked or chipped on the lobes. try the finger squeeze test on a few hlas. check your pulleys too - make sure you don't have one thats separating or wobbly (thus hitting the timing belt cover, block, or etc) Given how pronounced the ticking is, i would get under the car too, and get her running. Use the stethescope on the bottom part of the block and especially the oil pan to see how bad it sounds down there... everything is really close in these motors... odds are its just a collapsed lifer or bad tbt... but you never know. |
[x]MX6 #2. SOLD [x]Toyota Paseo. 42MPG. [x]5.9 Jeep. #1's tow vehicle. Still faster than most KL's.//Modifications List |
#20 (permalink) |
you can do an engine flush 100x, your not going to get rid of the tick unless you clean the old hlas or get new ones. They dont circulate oil, so the thick old crap inside of them wont flush out the pin hole it enters into.
Also the tensioner is one of the most common problems. Even if it was 1k ago.. You cant really rule it out. Ive replaced 2 on the same car in under 200 miles. The owner bought them off ebay, untill finally I told him to get it from mazda because I wasent doing it again for him. |
#21 (permalink) |
well i would help but the video has been removed by the user, so i am off to find some porn peace out home slice
#24 (permalink) |
Mine must have not been bad ...or maybe just low on oil,,,because mine were ticking bad...after my 6 sat for awhile...not being driven...did the flush and they.ve been quiet ever since
Tired of burning up in your 6, my Mx6 has vent temps in the low 30's....I have the solution...Transform your 6 from a sweat box..into an ICE BOX.
