Old 5-14-08, 22:17   #1 (permalink)
  Total: 17 Power: 1
1994 Mazda MX6 Door Lock Problem
Hey everyone,
Just bought my first MX6 today and I love it...but it seems to have a problem with the door locks.
I can lock and unlock it from the inside and the passenger door will follow as it should, and I can unlock the passenger door from the outside with my key no problem. But when I try to unlock the drivers door with the key it will turn both ways but will not engage the lock to either lock or unlock it.
Obviously there must be a mechanical problem so if anybody could let me know what to check or what will need to be fixed that would be great.
Thanks!
jmitch62 is offline   Reply With Quote
Old 5-15-08, 0:00   #2 (permalink)
  Total: 21 Power: 4
you can try taking off the door panel to see if the lock mechanism is even hooked up..if it is the lock cylinder might be crap
JollyGreenGiant
JollyGreenGiant is offline   Reply With Quote
Old 5-15-08, 8:25   #3 (permalink)
  Total: 17 Power: 1
Okay I'll probably have a look at it today..
If the lock mechanism is crap do you have any idea how much a new one would cost? Or if I was to head to the wreckers what cars other than the MX6 have a compatible lock mechanism? (I would assume most small Mazdas?).
Thanks,
Jordan
Old 5-15-08, 16:20   #4 (permalink)
  Total: 21 Power: 4
yes the mx-6, mazda 626, and ford probe are all pretty similar
JollyGreenGiant
Old 5-15-08, 23:41   #5 (permalink)
  Total: 20 Power: 2
ya the locks on or cars are junk, i've broken a lot of keys and i'm very gentle with my car. they either get jammed or just break, but i would def. check to see maybe its not hooked up anymore or out of its proper runner thus not working properly
good luck
'93 MX6 ZE Dark Force CAI, lightened Flywheel, 2nd stage clutch, walbro, FPR, and J-spec VAF/ECU
Doing the Research for FI...Coming Soon
2" lower kit for sale almost new ask for details
MaDkAtT44 is offline   Reply With Quote
Old 5-15-08, 23:46   #6 (permalink)
  Total: 11 Power: 1
what happens to me in my 1g is if i lock the doors while getting out and close them, the locks just pop back out! so i am guessing if someone walked up to my car bumped the door really hard, they would unlock themselves.
so i have to lock it with the key after i get out and the doors are locked.
endymion is offline   Reply With Quote
Old 5-16-08, 0:07   #7 (permalink)
  Total: 17 Power: 4
Endymion:
I have a '94 MX-6 and have found that the drivers door locks do wear out in time...faster than the passenger door lock,for obvious reasons. Door locks are not hard to replace nor that expensive, but the best solution really is to take it to a Mazda dealer and let them replace the lock, as they can cut the key to match and you won't need 2 different keys. Once the lock is replaced and working,don't use the key to lock the drivers door.
Instead,close (push in) the upper part of the inside door handle to lock the door,while holding the door open...the alarm light on the dash will light up when you do this.Then hold the outside door handle all the way up and shut the door. Then release the door handle. This will lock the doors without using the key in the drivers side lock,and it will last a lot longer that way. I always lock my doors this way,and the drivers side lock(and the key) have lasted for many years now without needing to be replaced.
Also be careful with the key after usng it for some time...the Mazda key blanks are not as strong as they could be,and repeated twisting of the key when locking and unlocking the door can cause stress cracks to appear in the smallest cross-section of the metal of the key. This can lead to the key snapping off. You want to replace the key if you notice these cracks developing...breaking off the key in the door lock would be bad enough,but you REALLY don't want that key to break off in the IGNITION LOCK!
porker999 is offline   Reply With Quote
Old 5-16-08, 0:27   #8 (permalink)
MX6.com Supporter - Click Here for Information Mat-su-Da
  Total: 28 Power: 2
If you're getting another key, and want a little style... look into the butterfly keys. Mine held up better than the replacments i got at the hardware store
SauerKraut is offline   Reply With Quote
Old 5-16-08, 11:22   #9 (permalink)
  Total: 20 Power: 2
ya lol mazda keys kinda suck, but porker999 is right that is the best way to go, i think all Gen. of the early mazda's have this lock problem good old solid mazda engineering
Old 5-16-08, 15:57   #10 (permalink)
  Total: 28 Power: 2
Easiest solution- Go keyless. Not the cheepest option though ;-)
