5-23-08, 0:56
#2 (permalink)
NJ,
USA
hmmm. if it was the trans, i would assume automatic, it wouldnt really be jerking like that if it was on its way out. check to see if theres something blocking the intake system. if not, go for the electricals such as spark plugs and wires. last thing i can think of is the fuel filter might be clogged or the fuel pump isnt pumping fuel properly...
hers: 93 ZE. pretty much the same mods. + F&R drilled rotors, STS, h&r's
