Inner Tie Rod Dimensions??? - Mazda MX6 Forums: MX6 Forum
Old 5-28-08, 15:07   #1 (permalink)
  Total: 17 Power: 5
reuben_johnston's Avatar
I'm looking for some help on finding out the dimensions for the inner tie rod. It would be easier if I didn't have to remove my steering rack to measure. Specifically, I'm looking for:
1. total length
2. outer tie rod end diameter, thread pitch
3. inner tie rod end diameter, thread pitch
The reason I am researching this is for my MX6 suspension. I would like to put the JIC RX7 inner tie rods and the megan racing RX7 tie rod ends on my 93 MX6. The RX7 inner tie rod dimensions are listed below and I want to compare vs. stock MX6 dimension. I am hoping it will be bolt on, as I would rather not fabricate custom ones.
total length = 300mm (end of outer side to shoulder on the inner side)
M12x1.25mm outer end, threaded for approximately 45mm
M16x1.5mm inner end, threaded for approximately 18mm
Thanks,
Reuben
Last edited by reuben_johnston; 5-29-08 at 9:00.. Reason: Updated with RX7 inner tie rod measurements.
1996 Mazda MX6 M Edition
2008 Mazda MX5 GT PRHT
reuben_johnston is offline   Reply With Quote
Old 6-2-08, 19:21   #2 (permalink)
  Total: 17 Power: 5
so i measured the outer end for the mx6 and its M14x1.5mm. can anybody help me out with the inner tie rod measurements? there is a nice bulk buy they have on rx7club.com with Superangle inner and Super*Now tie rod end package. if the inner tie rod size is identical, i can buy these.
rj
_______
Old 6-2-08, 21:47   #3 (permalink)
  Total: 152 Power: 5
Just go to an auto parts store and measure it.
Tired of burning up in your 6, my Mx6 has vent temps in the low 30's....I have the solution...Transform your 6 from a sweat box..into an ICE BOX.
94MX6pilot audio master is offline   Reply With Quote
