KLZE - Premium Fuel - Mazda MX6 Forums: MX6 Forum
Old 5-28-08, 23:07   #1 (permalink)
KLZE - Premium Fuel
Does anyone know if premium fuel in a KLZE is an absolute requirement?
1996 MX 6 Mystere
zinc is offline   Reply With Quote
Old 5-29-08, 9:28   #2 (permalink)
  Total: 342 Power: 5
whitenoyz's Avatar
no required, but I assume you're installing a KLZE for the extra power, right? lower octane gas will not give you as much power, thus defeating some of the purpose. Also, I'm not sure if pre-detonation occurs with lower octane gas, but why risk it?
Old 5-29-08, 13:10   #3 (permalink)
  Total: 152 Power: 5
Most cars with an ECU can adjust for various octane fuel...you may not get the most horsepower...but it will run and drive pretty normal
Tired of burning up in your 6, my Mx6 has vent temps in the low 30's....I have the solution...Transform your 6 from a sweat box..into an ICE BOX.
94MX6pilot audio master is offline   Reply With Quote
Old 5-29-08, 13:15   #4 (permalink)
  Total: 205 Power: 5
when i put in chevron 87, the car seems to run rough and lack power. improves tremendously after i put in husky/mohawk gasohol 90 octane.
99 Audi A4 2.8 Quattro Stock
94 MX-6 LS Mods: KLZE, I/H/E, Hi-Flow Cat, Steel clutch line, RR poly inserts, Short throw shifter, ACT HDSS clutch, MX-3 flywheel, Chipped ECU, J-Specs w/HID, K-Sport coilovers, RSTB, FSTB, 22mm Rear Stabilizer, Clear side markers RIP - Dropped valve since March 2011
Old 5-29-08, 14:59   #5 (permalink)
  Total: 342 Power: 5
whitenoyz's Avatar
agreed ghostling, when i first got this car, my dad once put in 87 octane since the old RS took that, and i thought I had fouled spark plugs until i found the receipt/culprit
Old 5-29-08, 15:49   #6 (permalink)
  Total: 411 Power: 5
the ZE can run 89 octane just fine. with gas prices the way they are right now, that's what i've been running in mine for the past 5 months and it runs perfectly.
damon™
1993 ford probe gt
1994 mazda mx-6 ls
2001 ford svt mustang cobra
dmark101 is offline   Reply With Quote
Old 5-29-08, 18:20   #7 (permalink)
  Total: 333 Power: 5
Check the condition of your plugs every once in a while with different octane gases. In the winter I use 87 and the plugs are a nice light brown. When it gets warmer, the plugs get whiter and I have to switch to midgrade. Unless you're taking it to the track, I don't think you need premium.
Old 5-29-08, 18:44   #8 (permalink)
  Total: 60 Power: 5
BOYZERO's Avatar
id spend the money on premium. even mazda recommends premium on a de. ive been using premium since i got the car couple yrs ago
93 MX6 LS,Boosted 6lbs,180 stat,udp,2.5in exhaust w/hooker aero chamber muffler w/3in tip,S2 clutch,11lb flywhl,strut bars,eibachs,monroes,awr f/r mm,awr sway bar kit,b&m shifter w/rr-racing&corksport brass bushings,. 1/4=15.0@92.5 n/a http://i215.photobucket.com/albums/c...lipboyzero.jpg-timeslip-stock cat,ecu,clutch/flwhl
Old 5-29-08, 19:45   #9 (permalink)
  Total: 333 Power: 5
Then Mazda recommended against premium on the DE because of carbon build-up.
Old 5-29-08, 20:06   #10 (permalink)
  Total: 1734 Power: 5
KING6's Avatar
premium is wasting money.
I only fill up with the highest octane I can get, because of the turbo. otherwise id get the cheapest gas in town.
Old 5-29-08, 20:13   #11 (permalink)
  Total: 152 Power: 5
The only thing I have to say about cheap gas is...I use it in my 2005 Astro work van everyday...and every year I have to replace the fuel filter because it gets clogged up. A new filter is only $10...so I don't care too much. I don't know if going to a higher grade would help it any...or if all the tanks at the gas stations are just full of crap?
Old 5-29-08, 20:45   #12 (permalink)
KING6's Avatar
maybe your tank is rusting out or there is material inside of it.
Or your filters are cheap.
Old 5-29-08, 21:00   #13 (permalink)
  Total: 152 Power: 5
There's always like black stuff in the filter....maybe the liner is deteriorating inside the tank? Hmmm
Old 5-29-08, 21:12   #14 (permalink)
  Total: 17 Power: 5
mushkid's Avatar
you can feel the difference, well i can feel it when i put regular!, it feels rough and slow and it shakes bad, when i add premium!!, it feels like it breathes and respond alot!!!alot!!! quicker!!!
Chuck Norris played Russian Roulette with a fully loaded gun and won.
mushkid is offline   Reply With Quote
Old 5-29-08, 21:16   #15 (permalink)
KING6's Avatar
yeah Id start pointing fingers at the componets before the fuel filter, before assuming is the gas station's gas.
yeah I dont think thats normal. Try a tune up? adjust the timeing?
The gas shouldnt make that big of a difference.
