this problem has been going on for some time now...
the car: 94 626 v6 5sp with HEI mod (NO EXTERNAL COIL) if say i do a second gear roll through a stop sign and lug the engine a bit it just about quits. its not bogging, i press the gas and it just quits/misses so badly that it wants to go down to idle/stall. then all of a sudden at the same throttle position it will fire back up with regular power... if it gets really bad at a light if i let it idle it will miss to the point where it will actually stall. If its missing and i try to take off sometimes i can barely get the car going since its just cutting out. once the car gets over 2000-2200 rpm it NEVER happens...it also does not happen until the car is at operating temperature. Things i've done: replaced disty cap (cracked) replaced plugs/wires wire brushed rotor contact. soldered all HEI connections (replaced self tapping connectors) other ideas: malfuctioning tps? fuel pump problem? internal coil problem? bad HEI ground (looks good to me tho...) Anybody else have any input? Last edited by vandejm : 6-20-08 at 15:17. |
