As the title states, I cleaned my iac, throttle body, and adjusted my tps using the proper method in diagnoses mode.
Now when I start the car it'll rev right up to 2,200 and then fluctuate between 1,500 and 2,200 over and over again consistently. *It has never done this before* I switched the tps with a known working one and the exact same problem in the same rev areas.
It would be great to find this out as this is the last step to fixing my problem.
Well I gobbed this brown gasket maker around there...the gasket was ripped at the bolt holes but I threw a bunch of gasket maker in there. Do you think a leak in the throttle body gasket would cause up and down revving consistently? It seems like an electronic problem.
Right as I start it, the revs go up to 2,000 then as they start coming back down it'll stop at 1,500 and then after about 5 seconds of idling it'll jump up between 1,500 and 2,200 non stop over and over again.
Take a paper clip, bend it into a U shape, then look underneath the cap that says "DIAGNOSES" and just like the fuse box, it'll show you what each little socket is. You want to stick one end in "TEN" and the other in "GND" or "GRND" which essentially just means ground.
I tried turning the screw in and out but once all the way in, it just sticks at 2,200 with a once-in-a-while rev down to 1,500. It basically slows down the timing of the fluctuating rev between 1,500-2,200.
I think I might have fried the IAC, I listened to another guy's post in another thread and he said that he hooked up the IAC to the battery to open the valve so he could spray into it. He used speaker wire, as did I, only I got sparking and smoke inside the IAC.
Could it be that since I may have fried the IAC that it would cause my idle to fluctuate when engine is warm?
kc, I'm in the exact same boat as you dude. My car also has trouble idling, it idles rough between 650 and 1,100 rpm and then while I'm driving you can just feel the power loss if the throttle is like a quarter depressed. If you manage to figure out what the problem is I'd be more than appreciative to hear if and how you solved it.
I am in the same boat to
I just droped in a new 93 PGT engine into my 93 LS. My idle is constantly at 2k rpm to.
The idle screw did not help at all. (does it have to be adjusted in diag. mode)?
I think is a vacuum leak, i was looking at my vac lines between the eng. and the firewall.
The vac line that connects to the EGR Solenoid was broken off of it the "male part". I'm not sure if it twas the Vent or vacuum solenoid, and I can not find one at auto zone
Does anybody know if this can cause a bad and high idle?
Also, a off the subject question. I have a MT, and when i press the clutch I cannot get it to go into gear. i thinkg the piece that goes into the clutch isnt connected properly. Is there a way to "re-connect" it w/o taking out the tranny?
I still have the problem but I just messed with the screw while it was bouncing hasn't acted up again but I'm sure it will. I hope we can all find out the answer to this a lot of people seem to be having this problem. The problem started for me after I installed an after market intake due to my stock intake having cracks all over it.
BAAAAA lol, sorry but SOOO many people tell me they have had the same problems. Every time I'm working on my car outside with the engine running and revving by itself, a random guy will Always walk up to me and say "it sounds like a vacuum leak" it's weird, and then I'll say "I've checked all the lines..." and he'll say "oh then adjust your TPS" and I just tell them that i've done all that and then they say how they used to own a probe "back in the day". It's kinda funny though because we all share the same problems.
This is what I'm gonna do, not tomorrow or the next day, but on the weekend I'm buying a new IAC valve and gasket. I'm gonna install it and see where that takes me. As I might have mentioned before...might have....this has Never happened before, this up and down revving continuously, it only happened After I cleaned the IAC and reassembled everything.
I'll do Lambera's vacuum leak test to see what happens, but I have to get some shut eye now, I'm picking up a classic set of TSW stealths from a guy tomorrow so I'll try and find time to test for vacuum leaks.
If we all work together investigating and narrowing in on the problem, then we can get a sticky posted up on how to fix this notorious problem with these cars. I'm surprised after all of these years that there isn't a solution, let's make history boys LOL.
i'm actually gonna clean one of my iac valves. took it apart today and took a look and things are black. going to use the cleaner that's safe for electrical components and spray it in there and then use compressed air to dry it off. i'm too scared to use straight up carb cleaner. hopefully it works. then i'll reseal with a bead of gasket maker on the old gasket. have fun finding a ZE iac valve gasket. it's not the same size as the de one
Ya I would drive mine but it's revving between 1,500 and 2,200 and it seems a little sketchy. Mines automatic though, so if I shift down to D the revs should drop right? My cars been sitting in the garage for about 4 months now and 2 of the tires are flat, and there's almost no gas left. I'm getting new rims and tires today though, so I'll slap those on and throw some gas in her.
Oh and what size are our lug nuts? No socket I have fits them...??
i just cleaned one of my spare IAC valves today. won't have time to put it in till maybe tomorrow or the next day. hopefully it fixes my issues. If you wanna check if it's your IAC, unhook it and see if it stop revving up and down. if it does, then your IAC needs to be cleaned or replaced
I just drove it a bit hard to work, petal to the metal style, to see if anything changed and I did notice that once I got off the highway it ran a bit cleaner.....but only for a minute. Then it went back to sputtering on and off while cruising.
Oh...ok lol I thought there was hope. I'll unplug the IAC like bmx said and see where that takes me. I hope to god it stops revving once its unplugged because I'd be screwed if it doesnt. I can get a rebuilt IAC for 45 bucks delivered to my door so it's an easy fix.
I'd like to take a poll here... I noticed for me that while I'm driving my car sputters when the throttle is a quarter or half way depressed and it has noticeable loss of power, but when I floor it the sputtering goes away and the car accelerates normally. Is this also the case with anyone else?
Related Threads
Mazda MX-6 Forum
2M posts
46.3K members
Since 2000
