mbxmotorsports has a kit with instructions on how to install. if you want the best, you go aeromotive for fuel lab. The mbxmotorsports one comes with one of these.
they sell the adapters for the fuel rail and stainless steel braided lines with the correct AN fittings
you'll also need to rig up a bracket to hold that afpr somewhere so it's not just hanging and bouncing around in your engine bay. i recommend using an aluminum bar that you can get from home depot or lowes for like 6 buck and cut and bend and drill it into something that will hold your afpr. aluminum is easy to work with as it's soft enough, but that bar will be thick enough to hold everything nice and sturdy
Originally Posted by tj.reid
what is the best Afpr to buy and how do u install it
